I wonder if flashing the fog lights when you hit the fob caused the problem. Seems like it would be sending a surge of current to the lights thus causing the failure. If I understand correctly the lights flash when you hit the fob. Just a theory though.
Although I can't speak for the surge issue, there should be no problems at all with flashing an LED. Flashing IS generally bad for HID bulbs, especially if the ballast doesn't support hot-restrike.
I'm leaning towards the "Cheaply Made" thing, myself, although I will give some credit to the heat issue, too, though I also find it surprising that they would heat up so much while in place like that.
