Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Popping sound during U-turn
  1. #16
    May 2003
    '99 Astral #1613
    Sounds about right to me, though I am similarly not too mechanically inclined. Yet. :-) Mine always does it in a very tight turn at low speed (then again I don't turn that tight at high speed for obvious reasons). The 5 mph TOD engagement is probably definitely it.
  2. #17
    1999, ASTRAL
    Got it too...
    My Cherokee did it, my Trooper did it, and my VX did it. I think the all do it. Normal
    NAVIGATOR
  3. #18
    Nov 2002
    Well the squeal Heraclid is mentioning on mine is during slow speed. VERY noticeable in parking garages! I recently had the VX on a lift running in gear (don't try at home!) with all the wheels off to locate the sound. Yes, it's THAT annoying! Come to find out it was emanating from the left rear hub. It would go away if I applied pressure to the outside brake pad but would continue if applying brake pedal. Strange, huh? I can imagine some of the light-bulbs coming on over some heads now! So I get all the wheels back on and get the VX to about 15 MPH and apply about a click or two of emergency brake. I do this in reverse and then repeat going forward again. Viola'! No more squeak! Apparently one of the e-brake system shoes had something on it or wasn't fully seated. I'm just glad it's gone! Very hard to look cool in a VX when cruising while going "squeak squeak squeak squeak".;pg;
  4. #19
    Nov 2002
    ARRGH!!! Just as I declare my triumph over the squeak it returneth! *grumble* *grumble* :madg:
  5. #20
    Aug 2003
    2001, Dragon Green #0891 [retired ;_;]
    Sounds like I have the same little squeak joe_black. It started about 24 hours after I got mine and it comes and goes. I can be driving along and not hear it for hours and then all of a sudden it comes back and is loader then ever. I've tried almost everything to get it to go away with nothing working. It originally started on the back passenger side and now its migrated to both back's and the driver front.
    I'm guessing it might be one of the following, shocks, springs, bushing or even the bolts on the rims.
    Another thing I've noticed is that I can reproduce the issue by "pushing" the car at an angle. (ie: just jumping up and down on it does nothing, but if I push/pull from the front corner at an angle I can somtimes get it to squeak)
    Maybe its just our dragons trying to get their wings spread. The funny thing is its the most annoying sound I've ever heard, I've gotten used to blasting the radio so I can't hear it.
  6. #21
    Feb 2003
    1999, White, Ironman 0918
    Mine was doing this since I got it from the dealer whenit had 14k miles. My uncle Alex the mechanic told me that it's just a beety tranny and not the front end. If must have something to do with power transfer to the front in low gear ???
    Ironman
  7. #22
    Nov 2002
    I like the winged dragon theory! LOL!
    It's definitely not the tranny. Like I mentioned earlier I had mine on a lift while running and in gear. Definitely coming from left rear hub/caliper area. I originally thought it was the CV boot until I did this. Now just to figure out WHAT in that area is making the noise. I'll probably pull the caliper apart and see what's going on in there. Stay tuned...
  8. #23
    Aug 2003
    Yeah, its definatly not the tranny. It normally occurs on uneven pavement, but like I said it can be reproduced in most cases by pushing/pulling at an angle. (ie: care turned off in park, or turned on doesn't mater) Definatly some kind a part squeak.
    I'm waiting for it to migrate to all 4 wheels and maybe I'll see her wings
  9. #24
    Aug 2003
    Hey Joe_Black do you have the upgraded bushings that Moncha offered a few months back? I'm wondering if that's not my problem. (havn't had time to actually get under there and check it, but was wondering if you had changed yours out and still had the squeak)
  10. #25
    Nov 2002
    I've got 'em, but they're in the "box of mods to be installed" waiting in the garage. LOL! It's definitely coming from the rear-left caliper area. After this next weekend I'll finally have some time to pull it all apart and see what's going on. There are some shim plates in the caliper and I suspect one of those may be hanging which in turn would inhibit the pad from clearing the rotor completely. I'll post pics and info when I do it, so hang in there!
  1. Popping Noise in Front When Moving
    By bartmanS4 in forum Ldub's After Midnight Topics
    Last Post: 03/23/2015, 04:42 PM
  2. Now it's my turn....
    By Gussie2000 in forum VX Troubleshooting...
    Last Post: 01/26/2012, 08:11 PM
  3. popping while turning.... ball joints?
    By LittleBeast in forum VX Troubleshooting...
    Last Post: 01/16/2011, 12:55 PM
  4. popping/clicking noise
    Last Post: 06/18/2007, 12:27 PM
  5. Headlight seals popping out
    By cooks 7 in forum VX Troubleshooting...
    Last Post: 07/10/2003, 10:40 AM
