Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Drop in MPG's
crager34 Drop in MPG's 01/22/2011, 09:53 PM
Cris Same thing happened to me. If... 01/23/2011, 04:09 AM
vt_maverick Can't you find a mechanic who... 01/23/2011, 10:52 AM
Ldub I'd guess winter blend fuel... 01/23/2011, 12:21 PM
Gussie2000 I agree with larry. Winter... 01/23/2011, 02:38 PM
Jolly Roger VX\'er I get 60 miles "easily" on... 01/23/2011, 03:29 PM
MSHardeman Did you have to remove the... 01/23/2011, 10:04 PM
tom4bren Crager, Didn't you move at... 01/24/2011, 02:18 AM
crager34 Did not remove the rotors. ... 01/25/2011, 08:43 AM
tom4bren They have meds now for... 01/25/2011, 08:53 AM
Ldub FWIW...:_confused I... 02/14/2011, 07:00 PM
nfpgasmask That was my initial thought... 01/25/2011, 02:57 PM
blacksambo Lucas gas treatment also... 01/27/2011, 01:13 PM
Mile High VX I use it with every... 01/27/2011, 03:40 PM
Junster Cold is really hard on 02... 02/13/2011, 08:54 PM
    Feb 2011
    2000 Dragon #0274
    Cold is really hard on 02 sensors. They need to be hot to work right. If they don't send the right mixture info quick enough the ecu will go to a open loop and ignore it. The mix will be like a carb thats got a stuck choke. This would explain the EGR problems many seem to be having. Running rich clogs the EGR. Also extended "warming up" will. Do these motors have a 1 wire or a 3-4 wire 02? The one that's on the engine side of the catalytic converter. The one aft just reads how the cat is doing. OBD2 vehicles always have at least 2. 1 wire 02's depend on exhaust gas temp alone to warm them. 3 wire 02's have a heating element in them, 4 wires the extra wire is a extra ground for the sensor cause exhaust hangers are rubber and sometimes the exhaust pipe itself has a very poor ground. If it's a 1 wire and replacing it doesn't help try wrapping the exhaust with header wrap about 6-8 inches above and below the 02 sensor. One more thing, did you accidently unplug your 02 when doing the axles? If you replace a 02 disconnect the battery. They can be sensitive and they are expensive.
    Junster If it don't looked fixed.. It ain't fixed.
  1. Differential drop?
    By Boonetown123 in forum VX Talk...
    Last Post: 09/07/2014, 04:49 AM
  2. diff drop
    By ramathorn in forum VX Troubleshooting...
    Last Post: 08/23/2012, 12:31 PM
  3. Drop Differentials
    By tomdietrying in forum VX Talk...
    Last Post: 03/30/2011, 03:52 PM
  4. My diff drop.
    Last Post: 04/03/2008, 09:30 PM
  5. gas mileage DROP!!
    By rainee25 in forum VX Modifications...
    Last Post: 10/31/2004, 07:25 PM
