one thing to do
Originally Posted by
mindaugas
Thanks, I feel a little less worried, just freaking out.
It was more than an 1/8 inch on the dipstick before I added. After I added it was at the full mark. I also check it twice, pull dipstick out, clean, back in, pull out, check, repeat. Oil looked a lot browner too. I have a feeling the oil was not changed by the dealer, I will make sure to do that this weekend with mobil1. I checked it twice over the 450 miles, each time I put gas in it, I was filling up at half a tank.
When u check it, do u warm it up first, or check it cold? I will be checking every day until I know. I'll leave the quart out and head home, stop half way and see where I'm at. It's only a 15 mile drive. I'll check before I leave as well. Wife is coming up to follow me just in case. And of course, forgot my cell. Oh, and this is all highway mileage, I know it's worse on the highway.
when you add oil wait long enough for it to settle. Otherwise the new oil hits the stick on the way down and shows full but really isnt. A PVC valve change at this time is a good inexpensive idea as well.
If the oil is low enough to cause the check oil light to come on one quart should not fill it to the full mark.
Carter Pewterschmidt
