Originally Posted by
Marlin
I had a near miss today. I gassed up, heading over to LKQ for the holiday half off pick n pull. The check engine light came on!! I had just topped off the oil. I ran the scan gage to check for codes. None!? How is that possible. I drove for about 5 miles and noticed the scangage would shut off and come back on. Turns out, when I did the foam flooring and seat swap yesterday (pics hopefully tomorrow), I bumped the OBDII plug. Turns out, if you get a loose scangage cannection, you can get a check engine light!! I plugged it in firmly, cleared the light (no code indicated, very weird) and away I went.
It's probably just pissed you aren't going to Moab...
