Results 1 to 15 of 29
Thread: Replaced Steering Wheel
    For all of those curious about whether or not the steering wheel is easy to replace the answer is that it is extremely easy. I chose a MOMO steering wheel and bought the stock MOMO wheel HUB (the only one they had for an Isuzu - basically looks like all Amigo/Rodeo/VX use the same HUB). It fit perfectly with no modification needed. Below is a quick write up which is really just a copy/paste from the service manual. I could do the entire process in 15 minutes now but the first run through I spent about an hour removing all the trim (which you do not need to do) and testing everything slowly. The horn does work but I had to get creative on connecting it. My comment is that if you do not feel like getting creative then do not count on the horn button working. The airbag light is perma-on and I will probably end up pulling the bulb from behind the warning light.
    Removal
    1.Turn the steering wheel so that the vehicle’s wheels
    are pointing straight ahead.
    2.Turn the ignition switch to “LOCK”.
    3. Disconnect the battery “–” terminal cable, and wait at
    least 5 minutes.
    4. Disconnect the yellow 3-way SRS connector located
    under the steering column.
    5. Loosen the inflator module fixing bolt from behind the
    steering wheel assembly using a TORX) driver or
    equivalent until the inflator module can be released
    from steering assembly.
    6. Disconnect the yellow 2-way SRS connector located
    behind the inflator module.
    WARNING: THE INFLATOR MODULE SHOULD
    ALWAYS BE CARRIED WITH THE URETHANE
    COVER AWAY FROM YOUR BODY AND SHOULD
    ALWAYS BE LAID ON A FLAT SURFACE WITH THE
    URETHANE SIDE UP. THIS IS NECESSARY
    BECAUSE A FREE SPACE IS PROVIDED TO ALLOW
    THE AIR CUSHION TO EXPAND IN THE UNLIKELY
    EVENT OF ACCIDENTAL DEPLOYMENT.
    OTHERWISE, PERSONAL INJURY MAY RESULT.
    7. Remove steering wheel fixing nut.
    8. Apply a setting mark (1) across the steering wheel
    and shaft so parts can be reassembled in their original
    position, then remove steering wheel.
    9. Move the front wheels to the straight ahead position,
    then use steering wheel remover J–29752 to remove
    the steering wheel. (I bought a generic GM steering wheel
    removal tool from a local auto store)
    CAUTION: Never apply force to the steering wheel
    in direction of the shaft by using a hammer or other
    impact tools in an attempt to remove the steering
    wheel. The steering shaft is designed as an energy
    absorbing unit.
    10. (not from service manual) I removed the black plastic piece with a yellow sticker (3 screws). To do this you will have to remove the housing around the steering wheel column. It's all of 5-6 screws with nothing complex. This was optional but if you decide to keep it you will need to remove (or file down) the airbag connector. I tried the wheel with it on and off and there was no noticeable difference so I removed it un-harmed incase I wanted to return to stock.
    Installation
    1. Followed instructions from MOMO install guide which was basically put on the hub adapter, horn ring, screw in fixing nut, horn button, put wheel on top and screw in six torx screws.
    MOMO hub (Part #7903),
    http://www.momousa.com/products/prod...suzu-hubs.html
    As a side note I've been in love my BMW 135i and have neglected the VX for over a year now. So my goal for 2011 is to continue to do some sweet mods to make it compete with the 135i. My next mod will be aftermarket seats (already on order). I assume that will actually require some time to install. Stay tuned!
    VERY NICE...
    Thanks for the info...VXinfo, that is...
    01, LineX tan/black, 1055
    Looks awesome, I like this wheel as well, would blend with our interior quite nicely:
    http://www.momousa.com/products/prod...g-wheel-2.html
    Sep 2010
    2001 kaizer vx
    Quote Originally Posted by darkl4805 View Post
    behind the inflator module.!
    just put 1 0hm resistor into 2 wire SRS connector - it will foul SRS module.
    (you may check exact resistance at air bag - and put resistor with exact Ohm reading)
    I pulled both of the SRS fuses that are under the yellow duplex fuse cover on the drivers side dash when I removed my steering wheel.
    Still driving W-0 the airbag in the wheel...no warning light.
    Dunno if that'll change when I install a new wheel & reconnect the horn...
    Mar 2010
    '01 Kaiser Gray VX#0867
    Wow that really looks great!
    I've seen the red/black version of that wheel, and I didn't really care for it. But the all black model looks fantastic. Good Work!
    I do also have an aftermarket Momo wheel, but I would really like a quick-disconnect for it. Anyone have any Ideas?
    '01 Kaiser SC'ed VX #0867
    Yeah, that's quite nice looking actually. My wheel is still in decent shape, but this is certainly a great option for those with dried out wheels.
    '01 Ebony #0939
    Yeah, that looks really nice, and I especially like the model name of the wheel you chose.
    Feb 2009
    1999,silver, 1516
    I can help you show your VX more love. Loan me the 1 series and I'll take good care of it.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    What about when you get pulled over? I thought I read somewhere that tampering with any vehicles restraint systems is against federal law. I'm not saying I wouldn't do it, just pointing out that this is pretty much staring any cop in the face when you get pulled over. The vehicross is great for hiding a lot of "questionable" mods due to it's rarity and most cops' unfamiliarity, but past a certain year, all vehicles had to have airbags right?
    Let ya know when I get pulled over
    Sep 2010
    2001 kaizer vx
    Don't know much about States Laws. In Canada air bag still an option. So to be on the road you don't have to have air bags in the car. Seat belts are mandatory, but not air bags.
    Nice work, although I think the chrome center looks a little more bling/sporty than the mundane Rodeo/Passport dash behind it. Maybe time to look at some chrome overlay trim to make it a smoother transition? In any event very nice!
    That's a pretty nice wheel you posted Chris, definitely like the gray accents better than the chrome. As a side question, does anyone know if all aftermarket wheels delete the airbag? Seems like now that airbags are standard on all vehicles sold in the US that aftermarket wheel manufacturers would need to offer some models with the airbag included.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I saw an ad for one with airbags in a couple of different car/truck magazines awhile back. But $$$$$.
    Feb 2009
    1999,silver, 1516
    Yeah, Grant wheels is now offering replacements that retain the airbag.
  1. Steering Box Replaced
    By bartmanS4 in forum VX Talk...
    Last Post: 06/03/2015, 02:54 AM
  2. Just got my JDM steering wheel!!!!!
    By Hcloud13 in forum VX Modifications...
    Last Post: 01/06/2014, 09:33 PM
  3. Steering Wheel...
    Last Post: 06/15/2011, 05:21 PM
  4. JDM steering wheel
    Last Post: 08/01/2008, 07:40 AM
  5. steering wheel help!
    By gabilangabby in forum VX Modifications...
    Last Post: 07/14/2007, 10:27 AM
