Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 80
Thread: I DID IT! Line X on my cladding...
  1. #61
    Jan 2011
    2001,proton yellow,0631
    are the fangs really made of titanium as ive heard they are...if so thats to unique to consiider covering IMO
  2. #62
    Nov 2010
    LINE-X,
    What's the process for masking off an area that you don't want covered? What I'm thinking about is masking off lettering in the center of an area that is going to be covered in LineX to let the original material provide just enough contrast to make it still visible. I'm not talking about real fine detail here, just a 4X4 or VX as far as the lettering goes.
    There are several methods which depend on the challenges involved.
    1. If it's an area that will not have thick bedliner material around it, simply use masking tape. However, you may need to use a razor blade to cut the bedliner material if it gets thick is a spot. Careful not to end up with masking tape underneath the bediner's edge, it will be very difficult to remove it!
    2. If possible, we use a wire tape. We can mask, spray, and then pull the wire to produce a perfect edge.
    3. Remove the emblem, apply the bedliner, glue the emblem on the bedliner material with "3M Emblem Adhesive".
    Quote Originally Posted by VXjunky View Post
    I believe it's just plastic.
  3. #63
    Quote Originally Posted by LINE-X View Post
    Thanks.
    That's what I was looking for. Do they remove the tape/wire while the LineX is still wet or after it has cured?
  4. #64
    Nov 2010
    LINE-X dries in 4 seconds and the wire can be pulled immediately. If LINE-X Xtra is used, it needs about an hour to dry. Then, the wire can be pulled.
    Drying and curing are two different things. Curing is the completion of the chemical reaction(s). It takes LINE-X (XS-100, the bedliner product) about 24 hours to cure.
  5. #65
    May 2009
    What VX? Rodeo Crew Cab, Jackaroo chassis, Supercharged 3.5, Navara tub (!!)
    No need to find a line thru the rocks any more - looks like you could just grind out a new path
  6. #66
    Aug 2006
    1999, Astral, Vehicross, 1619
    This is the color i want!!
  7. #67
    Looks like you and Marlin might match...
  8. #68
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Line-X, two questions:
    1) How much to do the exact same thing if I take off my own cladding? I'd want the side-view mirrors and hood insert Line-Xed w/the same material as the cladding, though.
    2) Do you use some type of adhesive agent on the cladding prior to spraying w/the Line-X?
  9. #69
    I'd want the windows and hood insert Line-Xed w/the same material as the cladding, though.
    WINDOWS???
  10. #70
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    WINDOWS???
    side-view mirrors, my bad
  11. #71
    Nov 2010
    Cladding and hood insert $550 with LINE-X and LINE-X Xtra. Can't apply LINE-X to the side mirrors, but we can apply only Xtra.
    We tried various primers, what worked the best was no primer, but we felt that the LINE-X must encapsulate the cladding.
  12. #72
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    In the research I've done, everything says that since the cladding isn't metal, yes, the part has to be encapsulated. $550 is inclusive of tax, correct? I'm not fond of the X-tra, I'd like the regular Line-X on the hood, too. If I separate the mirrors and you can encapsulate them, would you guys take that on, too?
  13. #73
    Nov 2010
    $550 is not inclusive of sales tax (only if you live in Texas).
    Standard LINE-X will fade over time, you might not be happy about that in the future. If you don't like glossy Xtra, there is an additive that cuts the gloss. The side mirrors have a hinge, the LINE-X may interfere.
  14. #74
    Is there extra cost associated with "de-glossing" the Xtra finish like I believe you mentioned above?
  15. #75
    Nov 2010
    I'd say $30 or so, which is just my cost.
  1. Line X on cladding
    By KRemo in forum VX Modifications...
    Last Post: 11/30/2010, 03:44 PM
  2. Line X, or Rhino Lined Cladding... How much did you spend?
    By taylorRichie in forum General Tips...
    Last Post: 10/16/2010, 01:07 PM
  3. Question About Line-X And Cladding
    By UNEVEN THOUGHTS in forum VX Talk...
    Last Post: 09/19/2005, 06:30 PM
  4. Line-X/Cladding Question
    Last Post: 08/31/2004, 07:54 PM
  5. Line-X on cladding??
    By IsuZOOM in forum VX Modifications...
    Last Post: 04/11/2003, 07:21 AM
