Results 1 to 15 of 50
Thread: Gasoline stain on cladding...best way to clean
VX KAT Gasoline stain on... 05/07/2009, 09:05 PM
etlsport i would pressure wash it..... 05/07/2009, 09:10 PM
VX KAT Yeah, it has the sticker, and... 05/07/2009, 09:13 PM
Jolly Roger VX\'er Yeah..just pressure wash it... 05/07/2009, 11:40 PM
Pepino My cladding is really really... 05/08/2009, 02:19 AM
Sprey When my dad went and filled... 05/08/2009, 04:38 AM
mrtew Try washing it with Tide... 06/16/2009, 04:08 AM
SomeBeach If it were mine I would go to... 06/16/2009, 07:36 AM
MSHardeman This might sound silly, but... 06/16/2009, 07:42 AM
    Went to a gas station this afternoon I'd never been to before, the auto shut off didn't work, poured gas down the side. I immediately used their "window squegee and that dirty water to rinse/dilute it, but I've still got a stain it appears. What's best to remove this? Something oily ...Windex, ???
    i would pressure wash it.. duno if yours has it still, but when i bought my VX there was a sticker there that said DO NOT scrub it if you get gas on it
    Yeah, it has the sticker, and I knew not to rub it, so I sloshed the dirty water on it with the squeegee. Ironically I just pealed that sticker off the window today.
    May 2003
    Wink
    Yeah..just pressure wash it and it'll be fine...done it many, many, times! As far as the Do Not Scrub....that I'm sure is more for dust that sticks to the wet fuel (then dries) and if you scrub now your basically "sanding" your cladding.
    At least that's my take on it!
    Oct 2007
    2001, foxfire red #1096
    My cladding is really really dark and it has happened to me too i cant get it to come off, it made my cladding look completly gray on that spot, this happened like 6 months ago and its still there i use armor all to cover it up, but as soon as i wash it off it comes back, that stain wont come off. i dont know if it is because my cladding is really dark but nothing i have tried has actually made the stain come off
    Albert Einstein
    When my dad went and filled the vx he spilled some on the plastic turning it the awful grey color. ended up just washing it off with some water and then using mothers naturaly black to the cladding back to its normal color.
    Aug 2008
    VX KAT--- You're exactly on track with the Windex!!! Use that first as Windex is a very mild cleaner. If that doesn't work, then try 409 Cleaner which is a bit more potent. 409 Cleaner will definately get it off, but always try the Windex first. If that don't work, then go back to the gas station that had the faulty gas pump and throw a pipe-bomb through the front door (just kidding).
    2001 Proton VX #0662
    Try washing it with Tide liquid or Spray&Wash stain remover. Since you've given up you've got nothing to lose until you get a replacement.
    Canadian VXer!
    May 2009
    2001 PROTON 0792
    If it were mine I would go to a good body shop. They have things that stores don't carry. I bet somebody that has experience in painting or detailing cars has something that would work. I would give up on store bought cleaners.
    2000, Ebony, VX, 0370
    Thanked: 12
    This might sound silly, but maybe head over to the Avalanche owners group and see if any of them have some experience with this. They have cladding similar to ours and may have found a solution. I know someone found one of the more "aggresive" cladding re-treaters over there.
    http://www.chevyavalanchefanclub.com...ard,111.0.html
    One of the guys had this to say:
    To take a stain off - like a gasoline stain, I use soft scrub.
    To make it shiny, or clean, I use WD 40
    If the cladding is faded like mine is, WD 40 makes it look like new again for a couple of weeks to a month.
    Another had this to say:
    Endeavorc,
    I just had this problem the other day. I was able to remove the "stain" by using a soft cotton cloth and some "Bug and Tar" remover. I had to go over it a couple of times but it seemed to remove the discoloration with no damage to the cladding. Hope this helps....
    Best Regards,
    Burt
    I would be VERY careful with WD-40 on the cladding. Test it in an inconspicuous spot first (as they say).
    Hopefully one of these works for you.
  1. For Clean Cladding
    By VehiX in forum General Tips...
    Last Post: 11/27/2014, 10:18 AM
  2. Help: Sudden strong smell of gasoline
    By twalker920 in forum VX Troubleshooting...
    Last Post: 07/12/2012, 06:23 AM
  3. so fresh and clean cladding
    By roguebrun in forum General Tips...
    Last Post: 05/07/2010, 03:36 PM
  4. Gave the VX a Clean
    Last Post: 09/01/2009, 02:05 PM
  5. What kinda gasoline you take?
    By zko in forum VX Talk...
    Last Post: 10/02/2005, 08:52 PM
