Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 35
Thread: What's the most backspacing you've seen?
    Have you ever tried this? Punch in the OEM specs and what you're considering and see if helps you visualize all these numbers.
    http://www.rimsntires.com/rt_specs.jsp
    Apr 2010
    says that VT_Mav provides useless posts, nothing directed at you. We all love VT!
    From marlins post, his wheels have an inch of back spacing more than factory. He is also running 34" tires. You should be fine
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Are you SURE about the backspacing? It sounds like you think OEM backspacing is 4.5"? As I posted, 5" is my calculation and 5.5" is what the chart says (that's linked at the beginning of the giant whee/tire thread). IOW, Marlin's backspacing is the same as factory.
    OTOH, with 9" wheels, I'd think they'd stick out more!
    Marlin, can you confirm your backspacing as compared to factory?
    BTW: Is there a (simple) adjustment for wheel lock-to-lock if there's any contact in that regard?
    Jan 2011
    2001,proton yellow,0631
    man that looks close to a sidewall puncture
    Quote Originally Posted by VXjunky View Post
    That's exactly why he's running the Goodyear Wrangler Kevlar MT/R.
    Not to mention why you air down before offroading. Tires will take a lot of abuse/flex at 5-10 PSI.
    01, LineX tan/black, 1055
    The sidewalls on those tires are close to an inch thick, and if I somehow do manage to damage one, they get replaced for free
    97 Jap Import, Black BEAST
    The VX has the best turning circle of any vehicle i've owned, so loosing a few degrees wouldn't hurt if you need too.
    Just for your information, my Isuzu is running an 8" wheel with a zero offset and 265 75 16 tyres. The tyre edge sits pretty much inline with the wheel arch (fender )
    The other thing to add is that with my set up and i presume others that haven't increased their off set out beyond the arches is that i get full travel of the suspension using the OEM bump stops, my wheels dont rub at all.
    I dont have any real front on pics so heres a close one
    And articulation wise, you can see things tuck in nicely.
  1. OEM Rims offset and backspacing
    By joshi in forum VX Modifications...
    Last Post: 11/12/2010, 09:27 AM
  2. wheel advice offset/backspacing
    By djvx in forum VX Talk...
    Last Post: 06/12/2010, 08:04 AM
  3. Replies: 2
    Last Post: 04/17/2008, 07:12 AM
  4. 15" wheel backspacing?????
    Last Post: 03/03/2005, 11:18 AM
