Results 1 to 5 of 5
Thread: Transmission
Threaded View
    Oct 2008
    2001, White, VehiCross, -
    Transmission
    Hi everyone!
    I have a couple of questions. We followed a tutorial on here, very informational. Here are some photos.
    Today, my sister and I changed the transmission oil and gasket/filter aswell. The amount of fluid that came out of the main pan was only about 1qt-1.5qt, so we remove the other pan(smaller) just in front of the main pan, about the same amount came out as well, 1qt-1.5qts. We did not turn on the engine or go through the gears while both pans were removed we didn't want to risk anything bad happening. After we put everything back together, we put 6qts of new fluid... Is this too much?
    If anyone is planning to replace their filter heres the bar you had to remove.
    4 Bolts on each end. 2 Bolts in the middle, remove the plate that the 2 middle bolts held, then theres 2 more nuts to remove. Make sure you have the transmission supported. We just set blocks under it (TOD), was fine.
    We kinda snapped a bolt, but thats normall of the bolt was rusting away.
    The car used to jump out of gear then back or at least it felt like it jumped out of gear, my grandfather told me because the filter may be sucking air through the filter hole when the car is on a tilt and there isn't enough ATF. Hence the hiccups. I test drove it today up the hill we go through all the time, no hiccups, none. But most of the time it does a hiccup, sometimes doesn't.
    If the ABS light is on, what can I do about the ABS? What should I check first?
    When the car is in Reverse, and Neutral the light indicator stays in "R". The only time I can get it to get into "N" is between Drive and Neutral. Does this cause any issues? How can I fix it?
    I forgot to mention. Sometimes when I have the vehicle placed in PARK. The vehicle will still roll a few feet then parks, sometimes not catching the park it just keeps rolling.
    DRIVE
    NEUTRAL
    REVERSE
    Thanks guys!
  1. Transmission - What Should I Do?
    By gunbarrelvx in forum VX Troubleshooting...
    Last Post: 07/27/2013, 12:37 PM
  2. TOD/Transmission Help?
    By dafman in forum VX Troubleshooting...
    Last Post: 01/27/2013, 06:54 AM
  3. TOD and/or Transmission in need of help!!!!
    By VCruz_52 in forum VX Troubleshooting...
    Last Post: 01/04/2013, 09:25 AM
  4. Hot transmission
    By Smokey in forum VX Troubleshooting...
    Last Post: 06/13/2010, 07:00 PM
  5. Transmission
    By melissayoung in forum VX Troubleshooting...
    Last Post: 05/15/2004, 07:18 PM
