our hubs are 100mm every isuzu from 92 until present has a 100mm hub except the ascender.
I think you are going to have a very hard time finding a hub centric wheel to fit the vx. I have never seen another vehicle with the same hub size as ours. toyotas are 108.. chevys are 101.5
EDIT. just looked again and the H3 says it is 100mm.. with same bolt pattern too.. i wonder if its a misprint though, the colorado and canyon both say 100.5
nothing wrong with lug centric wheels, the only time you run into problems is if you have deep lug wells like my wheels do.. and even then just put the lugnut into the socket and then into the wheel and once the first one is tight the rest are easy.
