I thought hub centric wheels went the way of the DoDo bird.
The only benefit that I've read for hub centric wheels is that they cut down on vibration. IMHO, that's total BS.
How can centering the wheel on a circle half the diameter cut down on vibration?
Hub centric was the way to go back in Grandpa's day because the technology just wasn't there to accurately and reliably drill out the lug holes on rims.
As a matter of fact, I believe that the hub is no longer even held to a tight enough tolerance during manufacture to get any of the benefit of using a hub centric rim. Sure, aftermarket companies do sell spacers to fill in any gap between the center bore and the hub ... made of soft plastic or aluminum. How is that gonna help with vibration?
