Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Timing Belt Failure
    Thumbs up here you go
    Oct 2010
    1999, Empire Blue Mica (Blue Streak), Ltd. 87/175 #1787
    Cheers.... looks like 3/4".... or perhaps 20mm...
    thanks for this... i will get back when I get around to having a go at drilling it out...!!!
    Oct 2010
    needed a puller to get crankshaft pulley off...
    Oct 2010
    Fractured cam belt tensioner pivot pin. Remnants still in Block.
    1997 Silver JDM 0623
    hi its not very long about 17mm - and its been over tightened !!!! no other reason - lets take into account it doesn't hold the tensioner on lol its just a bolt which the tensioner rotates around - so its not a tensioner problem -
    you will find the bolt section should just turn out - as its not a tightened bolt like i said - use a reverse drill bit or a nice branded punch the tuen it out no need to drill - i have some drill bits from snap on which would be perfect to snag it and turn it out
    regards
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
    2001, Proton Yellow, #0580
    Drill and use an easy-out. Be careful not to mar the threads in the block when you drill your pilot hole. It shouldn't be too bad - the bolt is large enough. I'm not sure how hard the steel is in the tensioner but from the way it sheared it's probably not case-hardened. Just take things slow.
    For the plastic covers - you should be able to find those in a junk yard from any of the other 3.2 or 3.5 motors in Isuzu/Holden/Etc vehicles (also Honda Pilot/Acura MDX).
    -- John
    Oct 2010
    back from break with family so getting back under the hood....
    thanks for the tips guys... I drilled and used easy-out....
    as it had snapped it wasn't very tight and came out relatively easy (as Greasemonkey suggested)... put cam belt on last night... (kit from Rock Auto... dead impressed with price and quality)... then took it off again... then put it on again... feels like good compression over 2 revolutions so hoping valves are OK.... will try to get some timing covers before the weekend..
    cheers again
    david
    Aug 2005
    1999, silver, 0887
    Remember for the 3.5L the factory mannual for cam timing is off. You must go by the later issued service bulletin data sheet to get the cam timing right...for 3.5L. I don't know about the 3.2L, though.
    Oct 2010
    Only managed to source the lower timing cover which had been the most badly damaged... repaired the upper Left and Right with superglue for a trial and it fired up first time using the standard timing set up:
    Crank - notch to mark on oil pump RHS line on belt LHS
    Odd bank - spring to 12 O'clock index on cam cover then leave
    Even bank - spring to 9 o'clock then rotate 90 degrees to 12 O'clock index on cam cover
    and gotta give another plug for Rock Auto who got parts to the UK the week before Christmas when all UK deliveries were stuck in the snow. QUALITY
    I guess we might also conclude that as my tensioner "fell off" while in the fast lane of the M27 the 3.2 JDM is non-interference...
  1. Did I screw up my timing? Timing belt replacement
    By workmeistr in forum VX Troubleshooting...
    Last Post: 04/13/2015, 07:26 AM
  2. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 08:09 PM
  3. Timing belt replacement and timing videos
    By deermagnet in forum Archives
  4. Timing belt ???
    Last Post: 12/15/2005, 10:34 AM
  5. Timing Belt
    By weasel in forum VX Talk...
    Last Post: 12/21/2004, 01:53 PM
