A few months ago, I sent in my VX for some 100k lovin'. One of the problems they spotted was that the brake fluid cap was loose, causing brake fluid to leak. Their solution to this was to just replace the cap with a new one.
When the new one arrived, the tech screwed it on, wiggled it around, found that it was still loose, shrugged, and continued with his day.
Today, I was checking the VX fluids, and after missing the oil filler and pouring half a bottle of oil down the side of the engine (Argggggh...), noticed that I was low on brake fluid again.
So, here's the thing. My cap is loose -- apparently loose enough to leak out during what they call 'spirited' driving. Which would also seem to suggest that it is also soaking up moisture from the air, too. This seems like a Bad Thing to me.
Is your brake fluid reservoir cap loose? There really isn't a way for it to not be tightened enough, since the molded cap fits into molded grooves, so I have to think I'm missing a gasket or something, but that should have been part of the cap, right?
