Results 1 to 15 of 61
Thread: Front Diff drop help for 8" lift
    I'd love to see a side view...
    Its a tad top heavy/high center of gravity for my taste..
    ....but certainly eye catching
    I cant help wonder ...
    A) How much cladding/metal you have cut out of arches..
    ..especially rear of front & front of rear ?
    or
    B) How much is going to rip off when those meats compress up into arches..
    01, LineX tan/black, 1055
    or
    In my preps for the superflexy, I removed what was in those arches, nothing but plastic, the rest is hollow. I imagine he had some major cutting at the front part of the body seam though, and cut the lip off of the cladding, there is nothing under there either, just the tabs that the splash guards mount to. The rear on the other hand...I hope he doesn't have any plans of maintaining the two feet of wheel travel, I already rub, and his tires are 6" bigger than mine!!!
    im sorry, but i have to chime in with a little voice of reason...
    1. the VX has issues with 35's on a 4 inch lift, i completely agree with beau (ascinder), that your going to hear a huge POP the first time you try to roll.... or your going to make it half way down the block and run outta gas from flooring it to get your VX moving.
    2. our transmission, t-case, and axles are not NEAR strong enough to handle that much weight in tires, its gonna cost you a LOT just to get it to roll...
    3. and last, i have to say that it is extremely unsafe to drive a vehicle with that big of tires on it unless its a diesel pickup. (the VX braking just isnt going to stop that thing). and im actually a fan of bigger tires, but thats just rediculous.
    i guess i say, to each their own...... but DAMN im glad it isnt my bank account or neighborhood. because i would be afraid to be rear ended by you.
    Hi Marlin.
    I think you'll find that there is metal, and certainly at the lower rear of the front arches...
    I removed a section of the "Mud" insert and had to trim back about 1 1/2 inches of metal...not structural, just bracing between outer skin and body.
    Having changed to 35's some 5 months ago...I am still cutting metal and plastic everytime I go off road and flex/compress more than last time.
    (I believe Dub found the same when he went to 35's..)
    Not so much at back arches...but certainly front arches, front and rear.
    As for clearance at lower front of rear arches...
    As long as the rear wheel clears the front "at rest"..should be OK (ish!) when flexed as the whole deal swings back as it compresses.
    IMO, back of rear arches and inside top & lip of all arches is gonna get interesting with those 40's..
    FWIW..I envisage some serious cut and hack on the ORW at Moab next time..
    ... when I push it to the max.
    Jul 2009
    2000 silver 0742 and 2000 firefox 0758
    or
    I have all the plastic and even the pinch weld and lower fender mount removed. Just turning stop to stop they hit....may have to go down to a 38" swamper
    Jul 2009
    here's the side view for now. Stuff is just bolted on at this point. I am not driving it like this. Still needs brake lines bled and my shock adapters from Independent4x installed
    Quote Originally Posted by superstang460 View Post
    Based on that photo, I assume you aren't going offroad in it. There is no way those tires can fit in the wheel wells,and we have like two feet of total wheel travel in the rear. No where for that tire to go.
    Jo-I was referring to the tops of the arches, I too have removed all that bracketing and plastic in the rear of the front arches. I still rub sometimes on the trails, but not enough to matter, just rubber on metal
    Thanks for the Side View Stang....
    A picture is indeed worth a thousand words!
    Jo
  1. My Diff Drop Brackets!
    By ohiovx in forum VX Modifications...
    Last Post: 06/08/2018, 06:42 PM
  2. Diff drop pics
    Last Post: 02/02/2015, 09:55 AM
  3. diff drop
    Last Post: 08/23/2012, 12:31 PM
  4. My diff drop.
    Last Post: 04/03/2008, 09:30 PM
  5. Urgent Help needed-Front Diff Drop
    By BritVX in forum VX Talk...
    Last Post: 11/29/2004, 08:26 AM
