Results 1 to 15 of 61
Thread: Front Diff drop help for 8" lift
    Jul 2009
    2000 silver 0742 and 2000 firefox 0758
    The VX is back together and rides better than it did with just the torsion bars cranked up 3" for my lift. I'm clearing 38x12.50 swampers on 8" rims and can turn stop to stop with no rubbing at all even close.
    Installed cross drilled and slotted rotors and new pads all the way around and it stops on a dime with the 38's. She's a little slow from a stand still start, but gets up to speed pretty much like normal. Its weird driving this thing and clearly seeing the roofs of minivans haha.
    Final setup.... FRONT
    Upper and lower front control arms with 5" of lift built in
    Indexed the torsion bars for about 2" beyond that for 7" total up front
    STEERING
    Sway bar extensions made
    Rod end steering links made and flipped on top to decrease angle
    4" diff drop with 5 degree rotation for perfect driveshaft angle
    REAR
    919 springs
    2" poly spacer
    2" drop of upper spring seat for 7" total out back
    1.25" length added to upper and lower 3-link arms to center rear wheel
    3" panhard bar drop
    3" body lift on top of that, for a total of 10" over stock.
    01, LineX tan/black, 1055
    Video and pics please...
    Quote Originally Posted by superstang460 View Post
    STEERING
    REAR
    919 springs
    2" poly spacer
    3" panhard bar drop
    Were you able to use your original half shafts with this set up or are you running without drive to the front?
  1. My Diff Drop Brackets!
    By ohiovx in forum VX Modifications...
    Last Post: 06/08/2018, 06:42 PM
  2. Diff drop pics
    Last Post: 02/02/2015, 09:55 AM
  3. diff drop
    Last Post: 08/23/2012, 12:31 PM
  4. My diff drop.
    Last Post: 04/03/2008, 09:30 PM
  5. Urgent Help needed-Front Diff Drop
    By BritVX in forum VX Talk...
    Last Post: 11/29/2004, 08:26 AM
