So having a bit of a problem that has me concerned. When I'm sitting at a stop sign or light with the transmission in Drive and my foot on the brake, I get a vibration/growling noise about a second after I come to a stop. The noise is constant until I left off the brake, then it goes right away (I don't even have to accelerate). I don't experience this issue anytime else, not while in Park, Neutral, accelerating, decelerating, shifting between gears, etc. I've done a good amount of digging and it seems like all the related threads dealt with issues experienced in those situations. Does anyone have an idea what might be going on? The vibration is very pronounced and can be clearly felt through the brake pedal, bad enough that I usually shift into Park or Neutral at lights just to avoid the aggravation.
Thoughts? Thanks!
