Driver side of vehicle loud wind noise near side view mirror.
I have made a discovery ! Yay ! Drivers side door hinges are worn . The door tips out slightly along the a pillar .
Solution = New hinges .
I ordered hinges from Isuzu parts .com . Two hinges , Oops! I clicked the wrong box and ended up with a passenger side "right side" upper hinge and drivers side "left side"upper hinge . Dang! so I place another order for a Left side lower hinge . Why ? because I need the drives side hinges .
The following is copied from Isuzu parts .com website : "Catalog Note: LH or Left = Driver Side; RH or Right = Passenger Side "
I took my shinny new hinges ,just the left ones and painted them some color that's really close to dragon green.
Install time, I disconnect the wire harness and unbolt the door ,remove the top hinge from the frame and .... well it doesn't match my shiny green hinge that I just painted . I take a look at the passenger side hinge, and yep my shiny green hinge matches that one , same thing for the lower hinge.
As of right now, I have a shinny non painted hinge that is a RH hinge according to Isuzu parts .com , on my drivers side door . I put it there because it matched the one that I took off.
Can someone please help me figure this out . Either my hinges were mixed up during the original assembling of my vehicle in japan , or something else ?
