Results 1 to 15 of 18
Thread: head gasket problem?
    1999 silver 1346
    Some of you may have been reading my posts on overheating. well i brought it to a diffent mechanic who did a test by sticking what looks like the tube they stick in your exhaust for a emissions test into my radiator overflow tank and it reads CO2%. it read 182 and his conclusion is without a doubt its the head gasket leaking.
    since i have had trouble with mechanics in the past is this accurate? he said there should be no co2 reading in the overflow tank.
    also any idea how much a head gasket should run, he said labor is 900 and 550 for parts, that dont include rebulding the valves or timing belt stuff just gaskets and labor. is this a good price and do you think i would need rebuit valves? there is no loss of power only thing that happend is car overheats sometimes and the only way to cool it down is to rev the engine for about 15 seconds and the temp goes right down.
    thnaks
    adam
    It the fluid level in your radiator going down? Any oil present in your antifreeze or vice versa?
    In my experience a bad head gasket does not cause overheating, the lack of antifreeze because its leaking/burning off causes it. I have heard of head gaskets going bad from overheating though.
    While it may be a problem, in my mildly experienced opinion, its not THE problem. Unless you are burning through antifreeze that quickly.
    If revving the engine helps it sounds like more of a flow problem. Either air or coolant. I would.start by running the engine with a large fan blowing right at it. If it still overheats its likely a coolant flow issue. If that solves it, its likely a bad fan or a dirty radiator/condensor
    Jun 2007
    2001, Proton
    any other symptoms?
    Quote Originally Posted by zadam123 View Post
    thnaks
    adam
    Had similar problem with a different car. Turned out the heater core was going bad. A antifreeze odor in the cabin is a sign this is the issue.
    Carter Pewterschmidt
    1999 silver 1346
    No antifreeze mixed with oil and no loss of power and no smoke from exhaust but I did have to add 1 half gallon of antifreeze in 1 month. Also what about that test can it be wrong?
    Jun 2007
    2001, Proton
    In addition
    I went on this site. It gives an estimate of repairs when you enter vehicle, repair, and zip code. I did not have Staen Island so I used my zip it was pretty close.
    http://repairpal.com/estimator
    1999 silver 1346
    Here is another issue I noticed When my car is running hot My heater works When the car is running normal temperature Sometimes my heater blows out cold air Do you think this is a heater core issue Or could it still be the head gasket
    Jun 2007
    2001, Proton
    as to this
    I can only say maybe. I was only aware of the symptoms of the core issue since it happened to me. I can not say for sure if these additional symptoms were happening
    1999 Astral Silver VehiCROSS #1214
    zadam123, I think you're on the right track now. This is one of those rare times where a leaking head gasket absolutely can cause overheating. I wish it hadn't taken me 2+ years to figure this same problem out.
    Oct 2010
    1999, Empire Blue Mica (Blue Streak), Ltd. 87/175 #1787
    Head gasket
    Sounds like head gasket to me.... so you're leaking exhaust into the coolant... which will displace coolant which you have noticed that you had to replace... you will be able to smell if you have exhaust gas by removing the radiator cap and or looking for bubbling in expansion chamber on tickover.... when the heater matrix is full of exhaust gas you get no heat as gas is no good at heat transfer. When you rev it you manage to overcome the gas lock and get some heat.. As we run a V6 it might just be one gasket and someone on here will know if they are a pig to do...
    You could try the "magic green liquid" as a temporary fix as your head gasket leak appears quite small at this time and you may like some time before you bite the bullet. My experience is that this bodge will allow you to pootle (<2500rpm) around without loosing coolant for some time but who knows...!!
    take care
    1999 silver 1346
    I brought it to another mechanic and he tested my radiator cap which he said was no good since it was holding no pressure and he said that could cause overheating also my heater core blew out ( i think it happend saturday since my passenger side floor was soaked ) which is probably why my heater was blowing out cold air.
    now here is the tricky part he gave me a new cap and bypassed my heater core and the car so far is running fine, no loss of antifreeze , no antifreeze smell in the car and no overheating. Granted it is now cold outside so not sure if the whole problem is the heater core going bad with a bad radiator cap .
    If it was the head gasket would the car overheat in the winter as well? I have been driving it to work (25 mile each way) to work for the past 3 days and so far so good. I really hope this is the problem since i dont want to fix the heater core to only find out my head gasket is also no good. I love this vehicle but cant afford all of this work.
    BTW i was quoted 700 for the heater core is this accurate?
    2000, Kaiser, #0016
    Shows that $420-$720 for parts and labor is what to expect for heater core replacement. At least in my area.
    Jun 2007
    2001, Proton
    Imho
    You should be OK for short trips in the winter. But you will need to get this replaced before spring so why take chances. I think the repair estimate is on the high end I would get the part from Merlin mention the club for 10% discount then find a different mechanic who will instal it for a reasonable cost. You can save a decent % when you buy the parts because we get quality OEM from Merlin at a 10% discount and also the mechanic doesnt get to charge you more for the part than he paid without the discount.
    Yep, and I just found out from the local Firestone sevice center that they mark up parts 25%. I saved about $1500 buying my replacement engine myself.
    The only problem you might run in to is a lot of mechanics won't install customer-purchased parts. They'll feed you some line about not wanting to be liable for sub-standard parts (even if they are OEM)... whatever... Just find a local garage without that policy and you're good to go.
    Quote Originally Posted by phines View Post
    +1, that's what I do and it's a must for this vehicle since many of the parts have to be ordered from Isuzu. As for what to do, I'm not as experienced as these other guys, but I would recommend you fix what you know is wrong (radiator cap + heater core) ASAP then wait and see on the head gasket issue. That repair is WAY too expensive to do if you're not even sure it's the problem. But if those immediate fixes don't get the job done, then yeah I think you need to bite the bullet and get the gasket replaced.
    Btw, and not that this is helpful in any way, but moving from NY would likely reduce your repair costs considerably. Good luck!
    Jun 2007
    2001, Proton
    Talking No kidding
    [QUOTE=vt_maverick;210061.
    Btw, and not that this is helpful in any way, but moving from NY would likely reduce your repair costs considerably. Good luck![/QUOTE]
    Moving from NY would reduce your cost on everything
  1. Driving problem fixed/TOD problem realized
  2. Replies: 4
    Last Post: 04/05/2007, 04:06 PM
  3. egr gasket
    Last Post: 11/05/2006, 02:42 PM
  4. Head Light Gasket
    By alleycat in forum VX Troubleshooting...
    Last Post: 05/25/2005, 04:15 PM
  5. Head Gasket
    By XCross69 in forum VX Talk...
    Last Post: 01/07/2004, 08:01 PM
