Results 1 to 15 of 15
Thread: Multi-Part Question - Transmission Clunk
    Mar 2010
    2001 Ironman 0588
    ...having it inside the glove box sounds like a smart idea, what with the skid plates and all.
    Hey if for no other reason - having it in the cab would sure make the initial adjustment easier. Beats having to get out and crawl under (or pop the hood if installed there) over and over and over and over!
    Dec 2002
    '01 Ironman
    Before mine burnt on my exhaust I had the line pressure at 10% and delay on full or close to it 90%? Make sure you secure it well or you may burn yours too. Once you get it set right you won't need to change again so in cab is not necessary. The only time I messed with it was when racing 1/4 mile at the track I would up the line pressure to maybe 20-30%
    The higher you set the line pressure the harder the downshifts will be but it will shift faster on upshifts... adjust until it all runs smooth enough for you.
    If you decide to sell, I would like it. I loved the feel of the shifts once you had it set right.
    Not sure why but I had an IM tech make me take it off once to pass inspection FYI
  1. Dumb transmission question
    By housertl in forum VX Talk...
    Last Post: 07/31/2016, 03:30 AM
  2. Another Transmission Question
    By Cable Bob in forum VX Troubleshooting...
    Last Post: 01/30/2015, 03:04 PM
  3. Transmission Clunk from 2nd to 3rd
    By kpv in forum VX Troubleshooting...
    Last Post: 11/03/2013, 06:56 PM
  4. SC part (help) question...
    By Cyrk in forum VX Troubleshooting...
    Last Post: 08/14/2007, 07:08 AM
  5. part number question
    By willthethrill in forum VX Talk...
    Last Post: 03/30/2005, 10:42 PM
