When you pull the rear axle out, do you have to replace the seal or can you slip the axle back in?? I knew my dust shields were rusty but when I hit them with the sand blaster today, I could see all the way through them. I was wondering if I replaced the dust shields could I just slide the axles out, install the new shields and slide the axles back in. Thoughs or suggestions???
