Results 1 to 8 of 8
Thread: A little bit of a problem.....
    Sep 2010
    1999, Silver, 0447
    Well I have had an engine check light on for a few weeks so I hooked my car up to a computer today in auto mechanics at my highschool. These are the codes I got
    Po201 injector 1?*
    Po204 injector 4?*
    Po304 cylinder 4 misfire
    Po353 ignition coil c fault?*
    Po354 ignition coil b
    Anyone got any advice on fixing it? Anyone had the same issues?
    How many miles are on it?
    I would start by removing and cleaning the injectors, change plugs, clean the plug coils, assemble, and run some Seafoam.
    Start CHEAP before you draw conclusions. I wouldn't guess anything more until you whittle it down.
    May 2009
    1999 Ebony Black/Red
    replace coils 1 and 4 with the any of the rest, and run the codes again. if 1 and 4 will be working fine, then obviously you got those broken. if so, i got some laying around and will let you have two for the cost of shipping
    2000, Ebony, VX, 0370
    Thanked: 12
    I love this family.....way to go ZubrAZ.
    Sep 2010
    1999, Silver, 0447
    Worm my Vx has 99k miles on it. zubraz how much would shipping be??
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    lot less than coils themselves
    May 2009
    im in 85308. the weight: i would over-estimate to 2lbs max. I'm pretty sure one could fit into large bubble envelope
    Jun 2007
    2001, Proton
    Imho
    dont use the envelope they run it through machines and it can catch. Use one of the if it fits it ships boxes. The smallest ships for like $4.95 I beleive
    Carter Pewterschmidt
  1. HID problem
    Last Post: 07/29/2010, 06:28 AM
  2. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 06:57 AM
  3. Possible TOD problem
    By BritVX in forum VX Troubleshooting...
    Last Post: 02/17/2010, 02:21 PM
  4. need a help again with another problem.
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 11/16/2007, 06:49 PM
  5. AC Problem
    By wwstone in forum VX Troubleshooting...
    Last Post: 07/22/2006, 07:37 AM
