I believe there are 3 grease nipples on the rear drive shaft? I have found 2 of them so where is the third one? and is they any more grease nipples anywhere else? Any advice, photos would be great.
Thanks
Thanks
One on each of the U-joints and one on the drive shaft itself at the small portion towards the front.
They should all line up in a straight line...at least on mine they do.
http://www.youtube.com/watch?v=rzaNXz-ty34
aftermarket parts sometimes have grease points too, check your ball joints, swaybar bushings and tie rod ends for them
Awesome. Thanks you guys
