Yes, pictures please!!
And do let us know how it holds up with time and weather.
Anita
2000 Ebony #263
AnitaProtich.com
What did you do with the jams for the doors?
I'll buy your remaining 4 cans if you want!
CAN'T WAIT FOR THE PICS!!!!!
I've got to look into this and the T-S1 stuff a bit more. I already tried the Restore/Refinish and found that didn't adhere properly, most likely because I didn't prep the surface correctly. I was able to successfully blast it all off with a pressure washer.
But GatorBack was probably the next item I was going to try. I want a permanent coating, so hopefully this will be it. I've got to read up on the surface prep instructions and see what my buddy Luna-X thinks too.
