Supercharger w/snorkle?
					Well I am going to buy a drivers side fender from Bantan and see if I can't make this work. The plan (right now) is to use the existing setup (box) and run tubing through the inside of fender then come out in front of the mirror and run it up just where the door won't hit it. I know that there might be problems thats why I'm posting! My concern is, will this slow the air too much for a supercharged engine? Do you guys have any better ideas on how to make this smoother? I would like to run the tube straight out the side next to the brake reservoir so it doesn't have to actually u-turn before it gets to the engine, but is that "inner fender" replacable? Does it just bolt on, or is it welded to anything (firewall?)? How much is the "inner fender"? Is there such a thing as a cone filter in a box? I want this to work as a cold air intake also so I want it as cool as possible. My idea with the "cone in a box" is that there would be something like this, I think thats the best cool air flow you can get, just run it inline with the tube, as very roughly
shown  below :*** ______
   ------------------|   cone  \--------
tube to engine<---|   filter   <| tube to snorkle
  ------------------|_____/--------
                        cone box
