Well, you guys and gals will be pleased to know that you don't have exclusive rights to the VX engine gremlins.
After 3 years of faultless service, my beast has developed the engine idle gremlin.
Started out as an occasional increase in RPM when stopped at traffic lights etc, but quickly became a stall everytime the throttle is released.
Cleaned MAF sensor. Looks good.
Cleaned TPS. Looks good.
Cleaned IACV. It was very gunked up and took a lot of cleaning.
Conditions changed to a running rough at idle when cold, and occasional stall when hot.
Fitted new IACV.
Now will not idle at any time. Stalls immediately the revs drop below 1000 RPM.
I think the new IACV was the wrong one. Same externally, but the poppet valve looked a different shape.
I will swap them back over at the week end and see what happens.
Then noticed a hissing noise coming from the right hand side of the motor as you sit in the vehicle.
The only code thrown is P1404 which I think is the EGR valve stuck closed.
So, this weekend I will try and chase down the correct IACV, look at why the EGR is not working, and try and track the hissing noise.
In the meantime, I have got very good at left foot braking and feathering the throttle to about 1100 RPM.
Anyone got a part number for the IACV?? I couldn't find it in the parts list on this site.
Any other suggestions??
Thanks.
PK
