Results 1 to 15 of 21
Thread: TOD Locking?
    Sep 2010
    1999, yellow
    TOD Locking?
    Hey guys,
    what's your experience with heavy offroading when it comes to locking differential?
    Does TOD prevent wheels from unnecessary spinning and is it really capable when you are in deep mud or snow?
    Ive seen some vids where all 4 wheels are not fully locked as one of the wheel was not rotating..
    Thanx
    Mar 2010
    2001 Ironman 0588
    This tread has some interesting information: How does tod work?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    The TOD is not a locker, but by finessing the E-brake, you can get the limited slip in the rear to do some pretty good stuff offroad.
    Sep 2010
    1999, yellow
    Good info on that link, thanx.
    So maybe it's good idea to put airlockers on all wheels if going heavy offroading
    Also interesting issue about E-brake usage for preventing futile spinning of the wheel, so E-brake locks both or just one wheel? I think it's both...
    Apr 2010
    It works on both rear wheels and x2 for using it. I (knock on wood) have yet to have a "slippage" offroad using my truck, it stays in locked real good when we go out, a few people asked if it had a locker lol.
    01, LineX tan/black, 1055
    x3
    I like the aussie in the front, with manual hubs. Aussie is less than 400 bucks from Indy4x, and fairly easy to install...if you are mechanically inclined. The ARB air locker is probably 3 times as much, if we can still get them for the 10 bolt front end. Plus install is no walk in the park.
    Depends how much wheeling you are gonna do.
    I just as soon disable TOD, since I have manual hubs on front, and in 4lo TOD does nothing as the power is even split 50/50 all the time.
    Apr 2010
    I'm with ya there Chris. If I keep the auto I'm gonna at least swap out the TOD case for a manual one then that opens ya up for the Revo gears, or if I do a full swap it'll end up with the MUA5 5-spd. Where I live there is no real advantage to the TOD, maybe horrible rainy conditions, but it'd be nice to be able to select 2wd or REAL 4HI.
    2001 Ebony 0177
    I briefly considered gutting it and making it rear drive only, for the same reasons. I doubt the TOD has ever been engaged ever in mine. I have to remember to go on a shell road every year or so, just to stick it in low low for a mile or so. (I had the VX for maybe 4 years before ever used lo at all....it was tough to engage because of it....now doing it every year or so seems enough to keep it loosened up) 2WD makes more sense for me too
    Quote Originally Posted by Chopper View Post
    TOD engages every time you drive over 5mph. Watch the green lights, if you stomp on it, it may even go higher than just the first bars.
    2001 Ebony 0177
    other than the 5/95 or 10/90 split (or whatever it is nominally) It's never been in any low traction situations is what I meant
    ohhhhh, my bad. I too would like an honest to goodness 4high. I am not a huge fan of drivetrain electronics, electronic lockers and so on. If you get em wet, or a bad electrical connection, broken wire, you are screwed. At least with manual stuff, you can always over ride something or rig something up, and it doesn't care about water
    Oct 2006
    01 Green Dragon 00291
    When the VX gets up to about 100mph the TOD computer splits the power evenly between the front and rear tires. Just saying ! Florida turnpike and all, you know .
    Feb 2009
    1999,silver, 1516
    Quote Originally Posted by tjh View Post
    That's interesting. I've never heard that before. I don't plan on going that fast any time soon, especially with the tires I'm running. Still... intersting.
    mine has never done that .. you running 4 matching tires?
    Oct 2006
    Yes Sir, 4 matched tires . I had stock size highway tires , Now, I have slightly oversized off-road tires . I get the same result with either set off tires . Full lock around 100mph . I've done multiple pulls up to 100 and let off , then accelerated again back up , and every time it switches to an even split at around 100. I'm not sure exactly what speed it happens at, but I do know that it's north of 95mph.
  1. Locking the TOD to 50/50 in 4H...on a JDM
    By Sakkie in forum VX Modifications...
    Last Post: 02/24/2015, 05:39 AM
  2. Manual Locking Hubs
    By Solitude in forum VX Talk...
    Last Post: 08/17/2009, 08:09 PM
  3. Disable locking gas cap/door
    Last Post: 02/04/2009, 09:35 PM
  4. locking hubs
    By 4x4boy in forum VX Modifications...
    Last Post: 06/01/2006, 07:47 PM
  5. ABS Locking?
    By Sheik-YurBooty in forum VX Talk...
    Last Post: 12/18/2003, 05:02 PM
