I am guessing that the tranny fluid has leaked out of the lines up near the front of the engine........ How do I check the fluid in this thing?! There is no dip stick for it like every other automatic I have owned. PLEASE HELP! Am I just stupid????
Try this...
http://www.vehicross.info/modules.ph...warticle&id=20
or this at post #32
http://www.vehicross.info/forums/sho...t=22005&page=3
Full tranny fluid change/check info.
From search function...
...search function is your friend!
ok so I pulled the "fill" plug and fluid came gushing out. Was that supposed to happen?
When checking Transmission fluid you ONLY pull the plug when in NUETRAL and Engine RUNNING !
If you check with engine OFF, fluid will pour out !
Now if you were in nuetral with engine running and pulled the fill plug and fluid gushed out then it means one of two things:
(1) Too much fluid in case (overfilled)
(2) Fluid way too hot to check
LFen
Yup..x2 Lfens thoughts.
See "FLUID LEVEL" below, as per post #32 suggested above.
Just purchased my vx...next day transmission slipping....wont eve go now
Heart broken about it too...you open one of two plugs on pan the upper one...
if it flows out of the upper plug its full ... no dipstick on the vx.
PS ANYONE HAVE AN IDEA OF AVG COST FOR TROOPER TRANS. USED PRICE ...ballpark...in case worse poss scenario. ...
Last edited by jarvis : 07/11/2014 at 08:53 AM Reason: my just purchased vx trans prob.
Jarvx
Member VXObsession can probably help you...they have a transmission shop in AR and are very knowledgeable and helpful...![]()
Jarvis, where are you located?
"Cast away the unessential to find the essence..."
WAG...https://www.google.com/url?sa=t&rct=...70810081,d.cWc
Not that I think this is the member in question...![]()
Just gave the OK to my transmission shop for a rebuild for $2100. First significant repair on the car at 191,000 miles. Best car I've ever owned.
