Results 1 to 8 of 8
Thread: Rear Differential leaking
    2001Firefox mica redVX 0834
    Question Rear Differential leaking
    Anyone have this problem? I just noticed a minor leak at the shaft input of the rear differential. I assuming it's the oil seal. Haven't taken it apart yet but might this weekend.
    I'll post up my results when I do.
    Andy C
    01 Firefox VX
    CT
    Quote Originally Posted by AndyC View Post
    Andy,
    Using our little search function, I found a few references to people having a leak in their rear differential. Unfortunately, they all took it to the dealer for repair. I couldn't find any references to anyone that did the work themselves.
    You may want to PM LittleBeast. He re-geared his last year so probably has some insights for you.
    Nov 2007
    1997 SILVER
    Be careful of this unless you know exactly what you are doing.
    IIRC there is a crushable spacer under the flange nut, that sets the preload on the pinion bearings. If you don't replace this spacer and set the load on the bearings correctly you will end up with a hell of a howl from the diff, and premature wear.
    To do it the correct way, you would need to pull the axles and diff out, and set it up on the workbench.
    Even the easy way with the diff still in the car, you at least have to pull both axles out, to set the bearing preload correctly.
    My diff has a weep around the seal, but it will be left until it is a real leak before it gets fixed.
    Good luck.
    PK
    Humm I did try a search but came up with nothing ? I guess I might check to see if it falls under the drivetrain warranty - think I still have coverage
    PK - Sounds pretty intense - might be better to see if I can get it done under warranty
    Thanks guys for the insight.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    If you end up not having it under warranty, I have a non leaking perfect condition third member(complete differential) sitting on the bench right now. It's absolutely worthless to me, so I'd let it go for real cheap.
    check the breather tube that comes off the top of the diff. mine used to clog up all the time and i would get fluid coming out from right where you are describing. after putting a breather filter back there and eliminating the cap, no more leak!
    Jul 2014
    1999, White, Ironman, 1993
    Rear 3rd member
    I realize this is an old post, but you wouldn't happen to still have that 3rd member available would you?
    Thank etlsport I'll check that. I can't imagine the seal is bad since I'm at around 50k and it's had a good life
    ascinder I'll keep you in mind but your far away
  1. Rear differential
    Last Post: 11/01/2011, 10:55 AM
  2. It seems like my rear seal is leaking
    By blacksambo in forum VX Troubleshooting...
    Last Post: 07/26/2011, 10:15 PM
  3. Rear Differential Offset
    By waymore35 in forum VX Troubleshooting...
    Last Post: 06/20/2011, 08:11 AM
  4. How to replace rear differential
    By LittleBeast in forum VX Modifications...
    Last Post: 06/11/2009, 12:47 PM
  5. Rear differential whine?
    Last Post: 05/21/2008, 09:45 PM
