I am in the middle of installing my new HU and hit a major problem! One the Antennae wire is too short so I need toget one from best buy tomorrow. But the new head unit won't turn on at all. I checked and re did the connections in the wire harness that ran the power, ground, acc, illumination and it does not work. I tried plugging the factory head unit into the stock harness and that won't turn on. The antennae connection is resting in the DIN so I do not know if that is causing the problem. Can anyone please help? Is that anntenae cable shorting the system? The fuse on the back of the new radio is okay, but I do not know which fuse in the cabin is for the radio so I have no idea if it is just a fuse.
					 Please Help!
 Please Help!
