Results 16 to 23 of 23
Thread: Transmission Flush, panacea or poison?
Threaded View
    2000, Kaiser, #0016
    Had my VX in the tranny shop recently, and he fixed me up good, runs great, smoother than it ever has. However in our discussions he stated he is not a fan of doing a "flush" on a transmission with an unknown service history.
    His reasoning is that if the tranny has been neglected for so long that doing a flush and fill with all new fluid will break up any tarnishing that has built up over the years, loosening things up and causing more problems. His take on it was that a full fluid replace introduces so much new detergent into the system that it can make things worse.
    He stated that he has seen it so many times on our sealed systems that he does not recommend it unless it has been known to be done at regular service intervals. He stated that doing a full drain and fill on a transmission of unknown internal condition is likely to DECREASE its working lifetime and often require a re-build or replacement sooner than otherwise. The service interval for our transmission (drain and replace fluid and filter(s)) as I recall is at approx 55K miles. Mine has just over 110k. I have no record of the PO having the trans serviced at all tho the records are spotty.
    Furthermore, he stated that the whole concept of a "backflush" which I interpret as flushing out the fluid and debris via reversing its flow for a short period is a complete falsehood. He stated that the valves in the txmission are not designed to allow a backward flow (seems logical to me!) and that the mechanics who say they will perform a backflow are selling snake oil. Yes, they can push it back thru a bit, but never thru the entire system. And again his concern is by backflushing even a bit you would just be re-introducing particulates right back where they came from which would accelerate wear.
    That is his position on the subject, I look forward to comments.
    As for the mechanic himself, he lives, eats and breathes transmissions. Its all he does. He has worked on Troopers and Rodeos extensively and more than one VX. And if indeed his advice was correct he just lost money. For if he had flushed it out like I asked which would in his mind precipitate a sooner than later overhaul, then he just shot himself in the foot profit wise.
    As it was he just checked for leaks, topped off the fluid which was really low for some odd reason, (there were no leaks). And sent me on my way for 10 bucks. I tipped him a 20 spot since we sat and chatted so long taking up his valuable in-shop time.
    What say you all?
  1. Transmission Back Flush
    By Mark B in forum VX Talk...
    Last Post: 06/03/2008, 04:52 PM
  2. Transmission Flush Question
    By Mikeys00vx in forum VX Troubleshooting...
    Last Post: 11/20/2005, 08:02 PM
  3. Transmission flush with new filter review
    By Syntek VX in forum VX Talk...
    Last Post: 10/07/2005, 09:09 PM
  4. Transmission Flush
    By Child's Play in forum VX Talk...
    Last Post: 01/09/2005, 04:33 PM
  5. Transmission Flush
    By wfjfg in forum VX Talk...
    Last Post: 11/09/2003, 10:29 PM
