Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 139
Thread: And so it begins...
    Feb 2009
    1999,silver, 1516
    I wouldn't think they would make the ride much worse, just stiffen up roll in cornering. At least that's the thought behind them. What they do in reality might be different. They might limit travel in off-road situations more-so than the stockers since they are stiffer.
    Jun 2010
    1999, Silver, VX, 0401
    Well today was another exercise in all things rusty. I was removing the axels, ball joints, shockes, etc to gain access to remove rust. The spindals were rusted so bad that when I hit it to break the ball joint loose, sheets of rust were falling off it. The brake sensor is rusted into it, plus the screws broke off into the spindal.
    The ball joint removal was going smooth as butter until the LAST bolt. I was removing the lower ball joint and was removing the back bolt the fits in the recess in the lower control arm. Well that area was so rusted that it no longer held the bolt causing it to spin. There isn't enough of the bolt sticking above the control arm to get a wrench on it. Anybody have suggestions??
    Shock question.....
    should the shock extend all the way out, as in under pressure? After removal mine stays where ever you put it. Pull it out, it stays.... push it in... no move...
    So over all not a very good day. Looking at 2 spindals, 2 break sensors anos possibly 2 lower control arms.... kind of expensive day....
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Shock question.....
    That means your shock is blown. If they have pressure(which they need to function) then they'll extend all the way out.
    If we're thinking about the same bolts, can you cut the nut off of the other side? If not can you wedge something in the top to prevent it from turning? I don't know how equipped you are, but an old screwdriver tack welded to the head of the bolt does wonders.
    Jun 2010
    I kind of figured the shock was blown, just wanted a second opinion to be sure. I tried wedging a screw driver down in there but no joy. I wish I had a welding machine I would do the welded screwdriver trick. I would also weld a bolt to the 4 brokencross member bolts. Yea... half the bolts broke. They had rusted so much that the upper neck was about a third smaller than it should be. I've been spraying PB Blaster on it and tapping them with a hammer but still have not gotten any of them to budge.
    ...can you cut the nut off of the other side? If not can you wedge something in the top to prevent it from turning? I don't know how equipped you are...
    Too little sleep or too dirty a mind I don't know, but this was pretty funny to me.
    Good luck with all this, should be amazingly better when you're finally through.
    Yeah I was going to say this will give Rickshaw a run for his money... and that's saying a lot. Nice job Buffy!
    If you can't see yourself in the diff cover when it's done then it ain't good enough...just ask rickshaw...
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    VXs don't have diff. covers
    Well then that rounded backside off the axle housing...maybe we call it the pumpkin...
    2001 Ebony 0177
    I forgot...the radiator support is particularly prone to crumbling on this vehicle. Might as well yank the radiator and clean all that up too...depending, you may have some metal to replace there
    1999, Ironman, 1705
    I just saw an explorer today that is whole undercarriage was absolutely clean and thought to myself "That would be awesome to see someone do on a VX!" and what do you know, i scroll across this..... AMAZING JOB!!! Can't wait to see it all done!
    May 2009
    What VX? Rodeo Crew Cab, Jackaroo chassis, Supercharged 3.5, Navara tub (!!)
    Thats nice
    My Jackadeo looked like that too.....then I got it running and found some mud
    How in the world... I can't believe I never saw this thread! Looks like you two are having a GREAT time!
    Just a heads up regarding the Calmini sway bars... to my understanding the Calmini versions are rated against the Trooper sways and using them on a VX actually increases body roll. The VX reportedly uses larger diameter performance sways than what's in a Trooper. Perhaps Chris/Marlin could measure the RS versus VX sway bars - not sure if that would supply the answer or not, but maybe?
    Keep on keepin on, but be safe - that teeter totter freaks me out!
    Jun 2010
    I decided against the Calmini sway bars. I took my stock ones and had them powder coated and ordered some greasable sway bar links from Indy 4X. It has been a fun project made even more enjoyable that the wife will get out in the garage and turn wrenches with me.
    Jun 2010
    Did some assembling this evening. I am hoping to have the rear end installed by tomorrow afternoon.
    Putting the rearend together with new stainless brake lines from Indy4X...
    Old and new rear bump stops...
    The valve covers with new higher metallic coating...
    A shame to cover all this work up, but at least it won't rust again...
  1. Isuzu Impulse RS... another obsession begins.
    By VXorado in forum Chit-Chat ...
    Last Post: 04/03/2015, 04:58 PM
  2. And so it begins...
    By jeeperkate in forum VX Modifications...
    Last Post: 07/13/2012, 02:43 PM
  3. VX Restoration Begins!
    Last Post: 02/02/2012, 08:39 AM
  4. ...and so it begins!
    Last Post: 06/19/2009, 02:58 AM
  5. and the silence begins...
    By ISCE in forum VX Talk...
    Last Post: 05/14/2008, 07:56 AM
