Looks like I am going to need to do this.
In preparation, is there anything I need to drain, or prep otherwise before I start taking the mode selector switch off and pulling the old seal with that nifty tool?
I would hate to get a mouth full of ATF![]()
IIRC, you can do it without draining the ATF. But I think I did a full trans service when I did mine so I had the pan dropped.
Thanks Bart.
hmmmm.....perhaps I should have my mechanic do it then?
I know its easy, but I dont have the setup for draining things.
Anyone else remember if its required to drain the atf first?
Bart - Any other tips before I get started? Are you still using that tool, or can I buy or borrow it from you? Otherwise, I can purchase it from amazon (its roughly $30)
Well, its buried in my garage somewhere, probably be faster if you just buy one.
