I assume that is parts and labor cuz I got my fan clutch for under 90 bucks with a lifetime warranty. At least u are fixed now!!!!![]()
Larry S.
99 Astral Silver VX (176k)
91 Porsche 928 S4 (73k)
WRONG! He replaced the fan clutch with the aftermarket one ( when you guys said it sounds like a semi you werent kidding) so i throw on the ac and head home and 20 minutes later its still overheating WTF! i turned off the ac and it cooled down to like half way maby a little more so I called him back and he is trying to tell me it may be my head gasket.
I thought if a head gasket goes the car looses power and smoke comes from the exhaust. I am tired of this guessing game, im out $600. Is there anyway it can be a themostat, he told me if it was no good it would get hot really fast which it dont.
Well, it certainly could be a head gasket, or a cracked head.
But that should have been the first thing your mechanic checked and eliminated.
The engine would only loose power if it is real bad.
And it would not blow smoke, only steam like when you first start up on a cold day.
1. Check for water in your oil. (Oil goes milky like creamed honey).
2 Remove radiator cap and run engine at idle, revving up and down a bit as you watch water in radiator.
If the oil is milky, or you see bubbles, or water squirts out, then the head or gasket is gone.
Good luck.
PK
