Results 1 to 5 of 5
Thread: Cel P1174
    Cel P1174
    Had my first CEL today...P1174 just as she turned over to 74K miles.
    Gauge I used said it was a lean issue upon acceleration. I reset it and it has not come back. If it does, then I guess I'll start with a new fuel filter.
    I use an injector cleaner with every other tank of fuel so that should not be the issue.
    Any other thoughts would be appreciated.
    Thanks.
    2001, Proton Yellow, #0580
    If that doesn't work look at the following:
    Clean the throttle body
    Clean the MAF
    Clean the MAS
    Often the issues relating to rich/lean conditions have to do with gunked up sensors or the throttle body.
    -- John
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
    Jun 2010
    2000 Proton VX 0630
    based on my experience with the Rodeo, the O2 sensors were a usual suspect
    Quote Originally Posted by johnnyapollo View Post
    Clean the MAF
    Clean the MAS
    -- John
    x 2...
    MAF cleaning has always fixed that code for me.
    Also, mine will occasionally throw that code when I get into the higher altitudes, even though I reset my CPU last time I was in Moab, it still popped a few times.
    Thanks for the help...that's why it's so great to be here!
