Results 1 to 3 of 3
Thread: Head unit install questions
    2001, Kaiser Silver, 0661
    Question head unit instal questions
    I will install a new mp3 head unit in a few days and have a few concerns.
    I have read a lot of posts and would like some advice.
    1. do I need to buy any adapters for the antennae?
    2. How do you insulate unused wires on the harness
    3. what is the best way to ground the new HU to the vx...elec tape to the chasis?
    any tips and advice are always appreciated
    Greg
    "What is that?"
    "That is an RV from hell...care to join me?"
    (from Tango and Cash)
    '01 Ebony #0939
    1) I think all antenna connectors are pretty much universal in nature, so I wouldn't think you'd need any adapters. Even if you do though, a place like Radio Shack would probably have anything you needed.
    2)I'm not sure what you mean by unused wires, but if they are by themselves with only a metal connector on the end, you can usually just tape them off individually so that there will be no possibility of electrical shorts in the future.
    3)Your ground wire is one of the most important considerations for electrical circuitry. There are usually a number of components up in the dash that are bolted to the chassis. Just loosen one of those bolts, and fasten your ground wire to it with an appropriately sized wire connector. It's best to find bare metal, so if the part of the chassis that you want to bolt your ground wire to is painted, scrape the paint off to get a good metal to metal ground connection. Check continuity to ground at that point by setting a voltmeter to measure resistance, and measure between that point and the negative post on your battery. The needle should read zero ohms for a good ground connection.
    '99 Astral #1977
    I had to get an antenna extension. The antenna lead was not long enough to reach to the antenna input on the head unit. No biggie... $6 at Best Buy.
    I had a couple extra wires too from the head unit that I wasn't using like the Antenna remote "on"...for power antennas, and some wire that would automatically mute the radio if I had a car phone hooked up and was getting a call. I just coiled them up and taped them off out of the way.
    RichD
  1. double din head unit
    By vxcp in forum VX Modifications...
    Last Post: 09/11/2016, 05:31 PM
  2. Stereo (head unit) replacement
    Last Post: 03/16/2007, 10:27 AM
  3. head unit
    Last Post: 11/29/2003, 12:44 AM
  4. new head unit questions
    By DeafVX in forum VX Talk...
    Last Post: 08/28/2003, 08:15 PM
  5. Need a head unit 2001
    By SCUDD in forum VX Talk...
    Last Post: 04/16/2003, 09:48 AM
