Results 1 to 12 of 12
Thread: mileage problem
    Oct 2009
    2001, Proton, 0617
    mileage problem
    i did a serarch, and couldnt find an answer. sorry if i missed it. i was geting around 19 mpg everyday driving, 21 on road trips. i just changed wheels and tyres and i knew it would afect my mpg, but not this much. (32" cooper descovery stt) i just calculated my new gas mileage. 10.59 mpg. 50% decrease! is this all due to the new tyres and the sligte lift that was required to fit acomodate them. or is there something else wrong? my driving habbats have not changed, and im a conservitve driver.
    Wink
    Quote Originally Posted by FlyingV77 View Post
    Have you compensated the mileage shown on the odo, to reflect the new tire diameter?...
    Input your stock size & new size here, calculate the difference in %, then take your odo reading x that % value, add that many miles to your orig odo reading, THEN divide by gallons used.
    Oct 2009
    2001, Proton, 0617
    i did think about that but how do i figure that out? is there a formula?
    wow dub that was quick! but i bet you hear that all the time i did think about that but how do i figure that out? is there a formula?
    Insult me, then ask for more help???
    Good idea...
    Re-read my original answer...it's all in there.
    Oct 2009
    2001, Proton, 0617
    thanks dub for the help. i didnt meen to ofend, i was teasin you. didnt see the link you posted untill after i replyed. im useing a not to smart phone, it doesnt always load everything on a page. i think i did the math right. the tyre size dif was 9.28%. so compansated i got 11.63 mpg. still seems like somethig is wrong.
    May 2009
    1999 Ebony Black/Red
    damn. i hope he doesnt hear it from his significant other
    Quote Originally Posted by ZubrAZ View Post
    A good thing for you funny little boys to remember...
    Whenever you point a finger at me or anyone else, there are three more, pointing right back at you...
    Jun 2007
    2001, Proton
    yeah but
    where is the thumb? Everyone always forgets about the thumb.
    We're talkin' A THUMB here right?
    I'm guessin' you'll be able to figure that out all by yourself...
    Oct 2009
    2001, Proton, 0617
    unless you do it Army style, then you gesture with the whole hand.
    That decrease isn't completely out of the ordinary for a few reasons
    Heavier tires obviously require more power to turn
    If you went wider a larger contact patch creates more friction, requires more power
    A more aggressive tread pattern with squared off blocks are harder to roll. Look at " fuel saving tires" they all have rounded off tread blocks and grooves
    New tires in general see a decrease in gas mileage. They are heavier than their worn counterparts. Plus the deeper tread flexes more than a shallow tread. This means energy that could be going to moving you forward is going to flex those tread blocks and then to move you
    In addition to that, you are also now less aerodynamic because of the height increase
    Check your tire pressure too if that's too low it will hurt your mileage. With oversized tires the best way to determine air pressure is to draw a chalk or grease line across your tires and drive a few feet then see if it's worn even across the tread. If it's worn on the sides your pressure is too low if it's worn in the center your pressure is too high.
    After your lift did you have an alignment done? Camber issues from an alignment can have a small effect on mileage because it causes the tires to not contact the road squarely
    2000 IronMan #11
    That is low...I run three different sizes and that is lower than all three.
    Things that could be wrong.
    -Calculation
    -PSI
    I would start by unhooking the battery for thirty.
  1. Mileage
    By cascabel3 in forum Polls
    Last Post: 09/09/2015, 05:16 PM
  2. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 06:57 AM
  3. Gas Mileage
    By Mile High VX in forum VX Talk...
    Last Post: 02/17/2010, 12:10 AM
  4. What is TOO much on MILEAGE!?
    By SachaK in forum VX Talk...
    Last Post: 09/12/2004, 11:46 AM
  5. Gas Mileage
    By Hanalei in forum VX Troubleshooting...
    Last Post: 06/08/2004, 08:00 AM
