Anita
2000 Ebony #263
AnitaProtich.com
Mine got louder after taking the restrictive elbow off.
Does the JDM version of the VX use the same trans.?
I don't know about the JDM version, but we don't have the same 4L30-E tranny as all those other makes and models. We don't even have the same 4L30-E that's used in most other Isuzu's. The 4L30-E has been around a long time and it gets changes almost every year. Our version of this tranny is only used in a '98+ 3.5L Trooper, that's it. It gets different components based on what specific vehicle it's gonna be used in. So they're not all the same.
This is what Isuzu says about our tranny-
"Though similar to the 4L30-E transmission used in other Isuzu models, the 4L30-E in the Vehicross has been modified to deal with the added horsepower and torque."
My tranny is rock solid at 234,000 miles and I wouldn't be surprised if I get 400,000 miles out of it.
Mark Griffin
Also the 350Z has about 10.3:1 compression and the Isuzu 3.5 is a bit over 9:1, just increasing the compression ratio and nothing else, you're only looking at maybe a 10-15hp increase at the engine at most. Also there is no tuning software for our trucks that we can just plug in and mess around with which sucks and I wouldn't trust a JET computer on anything I own. You can wire up a megasquirt to control the fuel/timing on our engines though which will help, HP Heaven can custom grind cams for the Isuzu V6's but they are in australia and the price will be a little expensive. Also, engine design plays a big part, just because one engine puts out the same displacement as another, doesn't mean they should be equal. Valve timing, ignition/fuel curves, stroke/bore, etc. The Nissan engine uses a shorter stroke and larger bore. We really have no "bolt-on" ways of making alot more HP out of these things so it's all going to be a custom [project until someone decides to start producing stuff. You can send your piston/rod off to someone who will make forged/billet versions of them, slap them in there, slap a turbocharger on it, megasquirt computer and tune it with 10-15psi of boost and you'll have a pretty peppy engine lol
The answer to all of lifes problems can be found here...
You're results may vary.
http://www.facebook.com/pages/Nitrou...e/270465350733
that's like, all crazy, and stuff....![]()
Tis true Dub, and I have used it many times. Probably going to run it on the 68' too. Just wouldn't run it on the VX for anything over a 50hp shot without better internals and a way to retard the timing + colder plugs. Nitrous is the cure for all things slow lol
You got to think of the VX engine as an agricultural setup. It just aint a performance engine, also sounds pretty crap for a V6!!!! But hey, it still grumbles!
thanks for backing me up, c-r...![]()
Tone ran Nos on his VX before the supercgarger....unfortunately all those threads are on the old board which no longer exists.
I am hopeing that by the time my VX engine gives up the ghost that there will be a few of those 2011 mustang v6's floating around the parts yards. Similar small package, 30mph (probably a bit less in the heavy VX) and 305hp stock. Would make a nice swap me thinks!![]()
