Results 1 to 2 of 2
Thread: Transmission Light Turn On And Hard Shift
    Apr 2010
    2001 VEHICROSS WHITE 1297
    My Vehicross Star To Have Hard Shift In 2 Gear And The Transmission Light Turns On... But When I Tunr Off The Car The Light Turns Off And The Car Shift Ok, But The Like 10 Minutes Later Is The Same The Light Turns On And I Have The Hard Shift..... Maybe I Have Overheating Transmission Problem, What You Gays Tink....
    Jun 2007
    2001, Proton
    first off
    you only need to post a question in one place people will see it.
    1. Take it to a shop and at least get an estimate and an educated guess as to what might be wrong
    2, A transmission flush might not be a bad idea.
    3. Have a local auto parts place run a scan if the tranny lite is coming on it may have a code for you.
    4. check back here other more experienced may have chimed in by them. Remember this is not a manned board with people waitng around to answer questions in real time.
    Good Luck
  1. Dome Light doesn't turn on with driver door
    By eblank in forum VX Troubleshooting...
    Last Post: 11/30/2011, 04:52 PM
  2. mode selector switch fix (shift indicator light)
    By kronopoliz in forum VX Troubleshooting...
    Last Post: 11/30/2009, 02:29 AM
  3. How to easily turn off the ABS light permanently
    Last Post: 10/15/2007, 11:02 AM
  4. Check Transmission light
    By nwdyver in forum VX Troubleshooting...
    Last Post: 10/27/2004, 09:38 AM
  5. Check transmission light
    By Andrey in forum VX Troubleshooting...
    Last Post: 06/27/2004, 01:26 PM
