Results 1 to 9 of 9
Thread: Smog Test Result: Rejected
    Jun 2010
    2001, Kaiser Silver, VX, 0726
    Smog test rejected (no failed) for 2 of 8 of the parameters not reporting; OBD EVAP and OXY SNSR HEAT. The check engine light came on after changing a very dirty air filter and upon starting the VX. I reset the system by disconnecting the battery. I have driven over 300 miles city/highway and still only 6 of the 8 have reported. They tell me I need 7 of 8 reporting to PASS.
    Any Suggestion?
    Jun 2010
    Quick Note; The Check Engine light is NOT on.
    My advice:
    1. Buy off the inspector.
    2. Move to a less green neighborhood.
    J/k, I'm sure others will have plenty of helpful suggestions.
    Sep 2004
    1999, Astral Silver, VX, 0938
    Quote Originally Posted by Troysaddress View Post
    Any Suggestion?
    Move to Illinois..no test. Run watcha brung,lol
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Sounds like either your evaporation canister(fuel) is either clogged or is leaking somewhere or the sensor is bad. For the oxygen sensors heat, you probably need a new oxygen sensor which is a PITA to remove. Either way it's gonna cost a lot of time or money or both.
    Feb 2010
    99 silver vx 1144
    Hey there now, northern IL does have emission testing. lol Thats why I moved back out of the city. Good to see another IL VX er there popping up all over up here lately. Three proton yellow and an White Ironman found in the last two weeks. Trying to get um all on the forum.
    They have emissions tests in Chicago, I have to do one every year...
    ~*~Cece~*~
    ____________________
    Maybe you could stick one of those battery-powered automatic air freshener sprayers in your tail pipe...
    "That's weird... in addition to the other read-outs I'm getting 1000ppm of potpourri in the exhaust."
    http://www.summitracing.com/search/B.../?autoview=SKU
  1. Supercharger and SMOG Check?
    By Cable Bob in forum VX Modifications...
    Last Post: 11/21/2014, 09:53 AM
  2. Need someone to test a product for me.. LED's
    By clipper 03 rodeo in forum VX Modifications...
    Last Post: 08/30/2012, 08:09 AM
  3. Shocker test....
    By alterastro in forum VX Troubleshooting...
    Last Post: 02/21/2011, 07:35 PM
  4. Aussie 2009 Condo 750 VX result
    Last Post: 06/12/2009, 12:33 PM
  5. Test Drive?
    By JAMAS in forum VX Talk...
    Last Post: 01/28/2009, 10:51 AM
