Another question!
If I were to use these Trooper shafts it has been said the balls are smaller. So does this mean I need to replace the entire long shaft, including the inner joint or will I be able to get buy with just the shorter shaft and using the old inner joint? I guess what I need to know is does that green cup need to be replaced?
If so, how much extra work is required to change that?
