Results 1 to 6 of 6
Thread: Cargo Door Adjustment Advice?
    Mar 2010
    2001 Ironman 0588
    Thanks, gang!
    It only took two tries before I found the sweet spot so now the door works perfectly. I guess I was just a little gun shy after messing up the driver's door - didn't want to get down to just 1 functioning door!
    Luna, I liked your tip about checking for play in the hinges. (They're fine, BTW.)
    2001, Dragon Green, 1342
    Thanks, gang!
    wonder if this adjustment would fix my rear door problem. Seems like every other time I close it, it will not latch at all and just bounces open. Might happen two or three times before it latches. Doesn't matter if it is opened with the key or the popper. But when it latches, there are no other issues.
  1. Valve adjustment
    By ahdoman in forum VX Talk...
    Last Post: 09/27/2014, 03:20 PM
  2. Headlight Aiming/Adjustment
    By VX4EJR in forum VX Troubleshooting...
    Last Post: 07/17/2014, 07:48 AM
  3. Torsion Bar Adjustment / VX Leveled
    By GPA in forum VX Modifications...
    Last Post: 08/09/2013, 06:17 PM
  4. EBrake adjustment?
    Last Post: 08/04/2011, 09:37 PM
  5. Torsion bar adjustment
    By sarge202us2003 in forum VX Troubleshooting...
    Last Post: 03/01/2006, 09:29 PM
