Results 1 to 6 of 6
Thread: tire sizes
    Apr 2003
    2001 Grey VX 0867
    tire sizes
    Just a few quick questions for all you tire gurus, is it possible to mount mud/dirt tires that are made for 17" rims onto the stock 18" rims of the VX? (2001) I have the money for new tires, but don't have the fundage for new rims and tires. So is this a possibility or am SOL and have to buy smaller rims for my off-roads.
    Regarding tire sizes, when they measure 285x60x18, I get what the 18 refers to, but what about the other numbers? What is the maximum size tire I can get away with height-wise if I install the OME 2.5" lift made for the VX? If anybody can give me some help, it would be greatly appreciated!!
    May 2003
    '99 Astral #1613
    Take this example:
    P205/70R16 89S
    The "P" stands for "P-Metric" or "Passenger". This means that it is a North American tire sizing designation.
    The "205" is the width of a tire, also known as the "section width". This is the width of the tire in millimeters at its widest point.
    The "70"is known as the Aspect Ratio. It is calculated by dividing the section height by the section width and multiplying by 100.
    The "R" stands for Radial, meaning it has a radial construction.
    The "15" stands for the diameter of the wheel in inches.
    The "89" is a load rating for this tire.
    The "S" is a speed rating for the tire.
    Feb 2003
    what would make you think that a shoe size 9 would fit on my size 11 feet? same concept
    2001, Ebony, VX, 1458
    Great detailed explanation!
    Originally posted by Heraclid
    Take this example:
    P205/70R16 89S
    Chet - CBA_VX
    1999, ASTRAL
    Lightbulb Re: tire sizes
    Allthough tires are primarily made of a pliable rubbery compound, I seriously doubt it is possible to do so without doing some serious damage to the beads of the tires and possibly distorting your rims as well. BTW if your objective is to have mud/dirt tires on a budget, you can get a set of 4 steel 15" rims in our six lug bolt pattern for around $100 and their are plenty of economical mud tires in that rim size, many for under $100 per tire. 15's are ideal for off roading IMO. Good luck
    NAVIGATOR
    Nov 2002
    01 FireFox VehCROSS 0459
    you have 17 inch tires
    So just go get 17inch rims
  1. "normal" tire sizes
    Last Post: 05/10/2007, 10:52 AM
  2. Tire Sizes affecting speedometer & ABS?
    By wekilled in forum VX Troubleshooting...
    Last Post: 05/03/2005, 11:01 AM
  3. Tire sizes
    By tooldini in forum VX Talk...
    Last Post: 11/22/2004, 07:36 PM
  4. help with speaker sizes please
    By valenki in forum VX Modifications...
    Last Post: 09/12/2003, 05:23 PM
  5. Tire Sizes
    By Medman in forum VX Talk...
    Last Post: 06/16/2003, 05:05 PM
