The problem is that you'd have to lift/lower the spare tire OVER the antenna, which would require you to lift it an extra 3"-6" (depending on whether you have OEM or JDM-style). You could always remove the antenna first I guess, but you also run the risk of crushing your spoiler if you drop it.
The other problem is that Tone hitches don't respond well to significant tongue weight, so lifting a 50+ lb. tire while standing on a hitch step probably would be a BAD idea. Can't wait to find a solution to that problem.![]()
