Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: U Joints
  1. #16
    yupe mine too, I am experiencing VERY loud vibrations in the drive line after letting off the accelerator. I just assumed it was bad gear mesh in the Diff or the vast change in the angle of the axle shaft after lifting. It definitely got way worse when I put in the 2" spacers, so much so I am thinking of removing them
    Ryan when you coming to Austin next? We can have a little meet and compare our noises!
  2. #17
    I light of the fact that Tom is off on vacation...
    I have no response to that...
  3. #18
    I almost fell out of my chair when I reread that....NOT what I meant.....Ryan knows me better than that, I 'tried' to give him a piggy back ride years ago at the houston museum......boy that floor was hard when I face planted!
  4. #19
    2000, Ebony, VX, 0370
    Thanked: 12
    I REALLY have no response to that....
  5. #20
    Oct 2003
    1995 Isuzu Trooper LS
    Quote Originally Posted by BigMeatVX View Post
    There is a Spicer replacment available for the front of the rear shaft, but I'm unsure of the rear one....
    I have had to replace my rear driveline @ around 200K due to the splines in the slip yoke being worn, and causing vibration...FYI
    What is the diagnosis for this? unhook the front end of the driveshaft and check for free play?
  6. #21
    Jun 2007
    2001, Proton
    remember
    The VX driveline has 3 lube points that need to be kept lubed.
  7. #22
    2001, Ebony Black, 1153
    Yeah, and for those of us with upgraded swaybar bushings we have 7 lube points, and if you replace the rear links it would be up to 13 I have been faithful to lubing and my u-joints feel A-ok, but the driveshaft is making all kinds of noise
  1. My U Joints are shot!!!
    Last Post: 06/04/2008, 11:41 PM
  2. how much are the Ball Joints?
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 03/11/2008, 05:24 PM
  3. CV joints revisited
    By tom4bren in forum VX Modifications...
    Last Post: 07/23/2007, 11:46 AM
  4. CV Joints
    By tom4bren in forum VX Troubleshooting...
    Last Post: 07/02/2007, 02:07 PM
  5. U-Joints
    Last Post: 04/28/2006, 09:55 AM
