[edit] Problem fixed. Mechanic just forgot to plug in the OSS.
I'm at wits end.
I finally took my 99 VehiCross to a shop to get the transfer case worked on. I was expereiniinc really bad "tight corner braking" or torque bind as I call it. I was also getting a rear speed senor TOD error light.
I had bought a used (only 8000 miles, $250) transfer case from a salvage yard and had the shop swap the whole thing out.
I got a call today and they said they are still receiving the TOD rear speed sensor error and want to replace it for $360. What are the chances that BOTH rear speed sensors are bad? I want to think that something else is going on, but not sure where to look. Any suggestions before I blow $360???
