Originally Posted by
ben-man
Hey Kat,
so, is that 303 stuff a cleaner as well, or just a sealer/protectant. I do have some lighter streaks on the cladding, but nothing that l would call oxidation. I guess what I'm asking is: would you just buy the 303 or would you clean it first with something else?
Sprayed directly on very dirty, grimmy roof rack parts (plastic end caps and the towers especially), wiped down with a rag, resprayed them and let them sit for a few hours. By then, it loosened dirt of any type, so I could just wipe it away AND it seemed to absorb into the plastic much more than just when sprayed and wiped it off. I heavily sprayed the inside of the end caps and cleaned them with Q-tips...so Joshi and VxMtb you'll be really impressed if you look inside there!
Made the black plastic look nice & dark and "moisturized", like new.
Think it would work very well on cladding! Except I don't know if it will remove prior products (B2B etc...)
Here's the product instructions....doesn't mention cleaning any item first...
303 Aerospace Protectant
"SPF 40 SUNSCREEN" For Your Stuff
Developed for aerospace and aviation applications, 303 is the world's most effective UV screening product. Unlike other "protectant" products, 303 does not contain silicone oils, waxes, glycerin or petroleum distillates. 303 leaves a like-new, non-oily, anti-static finish that does not attract dust. Treated stay cleaner longer, reducing maintenance.
Interior/Exterior: Vinyl & leather Interiors, plastic bumpers, fender flares, trim and lenses, car bras, tonneau covers, vinyl soft tops & Plastic windows, chrome and alloy wheels. Spray on, wipe dry.
Synthetic & Natural Rubber: for inflatable boats, wet/dry suits, tires, door & trunk seals and under-the-hood rubber. Spray on, wait 5 min. & wipe dry.
RV EPDM Rubber Roofing: Clean surface. Spray on mop on 3x3 foot area. Wipe dry. For your safety, never walk on wet roof.
Fiberglass: RV's boats, truck caps. Out of direct sun, spray surface with 303 and wipe completely dry. If streaking occurs, too much product has been used. Use a wet towel to remove excess, immediately wipe dry.
Motorcycles/ATV's/Snowmobiles, PWC's: Spray on wipe dry & polish to a high gloss. Also for gear... helmets, visors, goggles. Repels dirt, insects, snow ice and road grime.
Household: Patio furniture, spa and pool covers, vinyl liners & pool inflatables. Not for unfinished leathers (such as suede), fabrics (canvas) or floors.
Application:
Spray on, wetting the surface with 303. Wipe COMPLETELY dry. Turn cloth over to a dry area (or use a second clean, dry, absorbent cloth) and polish to remove any and all excess. Following these simple instructions.getting the surface wet (not just damp) with 303, then wiping COMPLETELY dry.will give you a beautiful, like-new finish that repels soiling and stains and LASTS LONGER.
KEEP OUT OF THE REACH OF CHILDREN, STORE & USE ABOVE FREEZING.
303 is non-toxic, non-flammable.
