Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: Scangauge X Gauge
    Jun 2010
    99, Silver, 1784
    ...the gizmo that may make the speedometer/odometer/shift points to compensate for my oversized tires.
    Could you tell us a little more about this gizmo? Inquiring minds want to know.
    -V
    -VI VX VNIVERSVM VIVVS VICI-
    Dec 2004
    '99 VX Astral Silver #0949
    -V
    Tone Monday; used to sell a speedo correction unit that had a series of Dip switches to correct the signal to the electronic speedometer.
    I thought about getting one, just for correcting the shift points for tire size.
    Many members have purchased these, I'm sure someone will add the links.
    Sometimes I Wonder......
    Why Is That Frizbee Getting Bigger?
    Then It Hits Me
    Mar 2010
    2001 Ironman 0588
    -V
    You bet! It's the Yellow Box Speedometer Recalibrator. I've hesitated to mention it before because it's never been confirmed to work on a VX by the manufacturer so I don't know if it actually might work of if I simply threw away $100. My research leads me to believe that it was designed to work primarily for motorcycles, but it also works for certain cars/trucks that use a "hall-effect type" speed sensor. After tons of reading, I think it *may* have a good chance of working on the VX due to my research on Tone's (RIP) recalibrator. Heck, I even have ALL the wiring mapped out already and have instructions that I converted into PDF form - I just haven't made the time to try it. Shame on me - I even forgot this was on my list of "things to do." I'll try to install it ASAP - hopefully this weekend now that I've remembered it.
    My biggest interest - doing the math to adjust my "real" speed is pretty easy since the speedometer is exactly 10% off. But I do think I'd benefit from having the shift points back. I hope I pick up a little MPG since my VX would shift up to 4th gear a little earlier around the 40 MPH mark.
  1. Scangauge recalibration - Tire size increase
    Last Post: 08/07/2008, 08:36 PM
  2. AC and MPG and scangauge
    Last Post: 07/11/2008, 08:51 AM
  3. OBD II ScanGauge II Mirror Mount
    By workmeistr in forum VX Modifications...
    Last Post: 07/06/2008, 07:50 AM
  4. OBD II ScanGauge II What's Normal?
    By Techy-D in forum VX Troubleshooting...
    Last Post: 06/25/2008, 10:47 AM
  5. scangauge questions
    Last Post: 04/25/2007, 06:53 AM
