Well I've spent the morning tearing into my engine to see if I can see what is going on with it. I did a compression test and here is what I found:
90 100
120 100
110 100
front
I took the timing cover off the passenger side and everything seemed ok. I took the valve cover off and still everything looked good. Had the wife crank it while the cover was off too see if I gould see anything going on. Got a good oil bath but other than that nothing out of the ordinary. The sound seems like it is coming from under the cylinder head now. Just not sure what my next move should be. What should the compression be on the cylinders?
I am perplexed because the tapping will stop sometimes and then go back to tapping.
Any suggestions???
