Results 1 to 15 of 16
Thread: Rear Axle Fluid - Bit-O-Honey???
    Wrench
    Quote Originally Posted by SilverBullet75 View Post
    Ok, question...
    This breather tube... can it come out (unthread?) then be extended/replaced with a longer tube (snorkel style)?
    Also, is there anything else that could have been damaged by the water?
    Thanks!
    ---JIM---
    You should be able to disconnect/replace the breather tube & route a longer one to wherever you want. Maybe even run it over to the driver side fender, behind the cladding where the cabin air exits. (one way vent) Or even bring it up under the hood, where the front diff vents, though the possibility of clogging would increase with length...
    Here's a good article on the subject...http://trucks.about.com/cs/4x4offroa...ad_driving.htm
    Also, I would drain/fill the diff a couple times with cheap dino oil, (run it for 10-20 miles to get things warmed up each time) then refill it with the good stuff of your choosing.
    In theory, the speed sensors could be damaged by soaking, especially if it's salt water, but if you're experiencing no problems with the TOD, they're probably OK.
    Also, all the mechanics of the parking brake (inside the drum) could be a bit corroded.
    I like Billy's idea of the bellows type air breather. May hafta look into that m'self. I don't think I've ever had to dunk my axle when launching the boat but you never know.
    the breather tube is super easy to remove/replace/modify
    mine kept clogging and building up pressure in the diff. i ended up installing a small breather filter (like some use in place of a PCV) a little higher up than the factory one.
    in your case i would probably do a combination of things.. maybe run a longer hose up towards the front and put a filter on it so that nothing can get in to clog the longer hose
    good luck with it!
    If ya want to get all fancy this is a sweet set up...a bit on the pricey side though.
    And here is the much cheeper bellow kit.
    Feb 2004
    '01 Ebony #0830
    Nice! I like the cheaper version. It's kinda like an air reservoir for the axle. That's pretty cool!
    Thanks!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Feb 2004
    '01 Ebony #0830
    Thumbs up wow...
    It's kinda funny how dramatically different the VX feels after replacing ALL of the fluids. It's like I just uncoupled a heavy trailer! Oh, and it's smoother and quieter than ever!
    Interested in seeing what my gas mileage goes to now. I was getting 18-19 Hwy MPG...
    What size tires are you running and what pressure? My gas mileage is running better than ever right now at 15 MPG...ugh.
    ... I was getting 18-19 Hwy MPG...
    Jerk!!!
  1. Rear axle seals
    Last Post: 04/21/2013, 02:44 PM
  2. Rear Axle Question
    By Buffy in forum VX Talk...
    Last Post: 10/18/2010, 08:35 AM
  3. front/rear axle fluid change
    Last Post: 04/13/2008, 11:58 AM
  4. Rear axle seal
    By Project Big 1 in forum VX Troubleshooting...
    Last Post: 01/21/2006, 08:20 AM
  5. Rear Axle leak
    Last Post: 04/30/2005, 08:03 AM
